stuart Posted January 22, 2009 Share Posted January 22, 2009 Hi all, Like a silly , I threw all my old foam from beneath the carpets out a long while ago!! Does anyone know off-hand the depth (inch - inch half etc) I have a local foam man who can supply............just thought I'd get it right. Cheers all................. Quote Link to comment Share on other sites More sharing options...
garymanc Posted January 22, 2009 Share Posted January 22, 2009 about 1/2" got mine out off the car,as it was wet,better put it back Quote Link to comment Share on other sites More sharing options...
spiney_norman Posted January 22, 2009 Share Posted January 22, 2009 Mine's all gone as it was wet and pretty much fell apart as I removed it. It's not that important surely? Quote Link to comment Share on other sites More sharing options...
greg Posted January 22, 2009 Share Posted January 22, 2009 Personally think it's best left out as it holds water and encourages rust. Quote Link to comment Share on other sites More sharing options...
paulmanta Posted January 22, 2009 Share Posted January 22, 2009 It deadens a lot of road noise. If yours has got wet and fallen apart you can use ordinary houshold underlay, its rubber and you can cut it to shape and it does help cut noise a bit, also it does not hold as much water as the old foam. A carpet shop/fitter should give you some for pence as its not a lot you need. Quote Link to comment Share on other sites More sharing options...
stuart Posted January 23, 2009 Author Share Posted January 23, 2009 Cheers all, I was just concerned with the fitment of the carpets if I used thinner foam etc. May well go down the underlay route.............cracking idea, not bothered about road noise as all the sound deadening has been binned as well!!!! Quote Link to comment Share on other sites More sharing options...
