maher the hermit Posted March 1, 2009 Share Posted March 1, 2009 Hi ive owned manta for mmmm 18 years or so and one thing ive never done is replaced the rubber bush in the cross member that supports the torque tube to propshaft bearing... ive managed to locate one what sort of a job is it to replace we talking loadsa swearwords Quote Link to comment Share on other sites More sharing options...
fjz400 Posted March 1, 2009 Share Posted March 1, 2009 Ive done a few its not that bad realy just need to open the flange nut then grip the propmount and away you go.... Ive managed to do one gripped in a workmate without using powertool/impacts the hardest part is gripping the tube tight enough to undo the nut once its off tho your home and dry as all just seperates quite simpley Quote Link to comment Share on other sites More sharing options...
