16" Wheels
retrocarclub
OK, going by the std manta GTE rims, they are 6" (150mm for arguments sake) on an et30. going to 8" will put an extra 25mm each side if you maintain a 30 et, 35 will put an extra 5mm again in the inside. you'd need 20mm extra clearance arch side and 30mm extra clearance on the inside.
that could be asking a bit much, esp if its lowered.
