Wanted Manta B Top And Bottom Wishbones
spewy555
If you can't find any ready to go. I've got a full subframe going spare so I'll need to get my windy-gun and spring compressors out. I'll be down my workshop this weekend so I'll see if I can a pic or two as they may be quite grotty by now.
Okay mate thanks. I'll let you know when I've unburied the subframe, I'm so bloody busy and messed about at work at the mo' I get so lathargic in my time off but I'll try and get it done in the weekend.
Thanks again.
Andy, I didn't forget but I've got a bit stuck, or rather all the ball joints are stuck fast. They all seem to be the originals which have been in since the mid seventies. I can't even get the track rod end joint out of the stub axle let alone the top and bottom ball joints, the nuts undone easy enough but I've used a ball joint separator and even jammed a scissor jack between them to try to pry them open, all to no avail :( .
