paul691 Posted August 28, 2009 Share Posted August 28, 2009 I have a Coupe with the SD1 v8 fitted by previous owner. Its an unfinished project and one of the things i'm doing is fitting a manual gearbox as its got a borg warner auto box in at the moment. I believe that i need to covert to hydraulic clutch, is that correct? any help would be great, or some pics of finished projects. Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted August 29, 2009 Share Posted August 29, 2009 The std V8 manual boxes did come with a hydraulic clutch, so the answer would be yes. I don't know what bits you have but you'll also need the flywheel and bellhouse. Alternatively you can fit a Capri 4 or 5 speed box using the auto bellhouse and run a cable clutch. HTH Chris Quote Link to comment Share on other sites More sharing options...
