MickB Posted September 4, 2009 Share Posted September 4, 2009 There is a gap in between the dash and glove compartment where the stereo should be and I am presuming there should be a stereo 'housing' of some sort there and this is missing. Can I get one anywhere? Many thanks Mick Link to comment Share on other sites More sharing options...
rayman Posted September 4, 2009 Share Posted September 4, 2009 There is a gap in between the dash and glove compartment where the stereo should be and I am presuming there should be a stereo 'housing' of some sort there and this is missing. Can I get one anywhere? Many thanks Mick If you find one or two let me know my stereo missing as well ...mick Link to comment Share on other sites More sharing options...
MickB Posted September 4, 2009 Author Share Posted September 4, 2009 If you find one or two let me know my stereo missing as well ...mick Sounds like they may be a bit rare! Link to comment Share on other sites More sharing options...
Beaker Posted September 15, 2009 Share Posted September 15, 2009 There is no housing that I know of. As far as I can work out the radio area was blank and at the factory or dealership they cut a mounting hole for it. Some cars are totally blank. The original radios were the type with two knobs and push buttons for your presets. Link to comment Share on other sites More sharing options...
philips Posted September 15, 2009 Share Posted September 15, 2009 hi mick, on the yellow A the previous owner had cut out were the stereo sat in,leaving that missing bit,you will need a new dash board, me and steve were after one but were unable to obtain one.i will try and get a pic up of mine so you can see what i mean. Link to comment Share on other sites More sharing options...
MickB Posted September 16, 2009 Author Share Posted September 16, 2009 hi mick, on the yellow A the previous owner had cut out were the stereo sat in,leaving that missing bit,you will need a new dash board, me and steve were after one but were unable to obtain one.i will try and get a pic up of mine so you can see what i mean. Thanks for this, looks like I may have to construct something myself when the time comes...or just sing to myself as I drive along! Still trying to get welding quotes on it at the moment to get it through an MOT. Will let you know how it goes. Mick There is no housing that I know of. As far as I can work out the radio area was blank and at the factory or dealership they cut a mounting hole for it. Some cars are totally blank. The original radios were the type with two knobs and push buttons for your presets. Thanks. I remember continually changing mine when I first had the Manta all those years ago, and adding a graphic booster etc. Mike Link to comment Share on other sites More sharing options...
philips Posted September 17, 2009 Share Posted September 17, 2009 ho problem, yeah let us know how mot goes when you get there. heres a pic of how it should be. cheers sean Link to comment Share on other sites More sharing options...
MickB Posted September 18, 2009 Author Share Posted September 18, 2009 ho problem, yeah let us know how mot goes when you get there. heres a pic of how it should be. cheers sean Thanks for the pic, that helps to know what it should look like. Car going in for MOT on Monday, basically only to find out all the things it will fail on and what I need to do to get it passed. Dreading a long list. Mick Link to comment Share on other sites More sharing options...
Robbie Posted September 18, 2009 Share Posted September 18, 2009 Beaker is right, there was no blanking plates made as the dash was uncut when made, if any car had a radio fitted the dash was cut to install it. If you wanted to blank it of you could modify pretty much any blanking plate to suit. Some sikaflex will soon hold it on over the ugly hole I just fitted a heead unit in mine, peroid ones look good but sound naff. Link to comment Share on other sites More sharing options...
philips Posted September 18, 2009 Share Posted September 18, 2009 good look on mot , your list shouldn't be as bad as mine,as yours is quite solid from what i remember sean Link to comment Share on other sites More sharing options...
MickB Posted September 18, 2009 Author Share Posted September 18, 2009 good look on mot , your list shouldn't be as bad as mine,as yours is quite solid from what i remember sean Cheers, as a matter of inetrest you don't remember what carb is fitted to it do you? There is a bit of cut out sponge where the air filter should be and I want to put on a proper filter. Guy looked at it the other day and thought if might be a Weber twin choke? Many Thanks Mick Beaker is right, there was no blanking plates made as the dash was uncut when made, if any car had a radio fitted the dash was cut to install it. If you wanted to blank it of you could modify pretty much any blanking plate to suit. Some sikaflex will soon hold it on over the ugly hole I just fitted a heead unit in mine, peroid ones look good but sound naff. Thanks. I like a bit of The Boss whilst driving so will have to make something to house a cd player! Link to comment Share on other sites More sharing options...
Robbie Posted September 18, 2009 Share Posted September 18, 2009 Just cut it the normal size and insert a head unit frame, Link to comment Share on other sites More sharing options...
philips Posted September 18, 2009 Share Posted September 18, 2009 hi mick, yes you are right the carb is a webber twin choke, hope that helps cheers sean Link to comment Share on other sites More sharing options...
philips Posted September 18, 2009 Share Posted September 18, 2009 Just cut it the normal size and insert a head unit frame, unlucky for mick he cant just cut a hole,as i remeber the bits in yellow have been cut out aswell leaving him with a rather large gap! if i remember rightly? cheers Link to comment Share on other sites More sharing options...
paul1393 Posted September 20, 2009 Share Posted September 20, 2009 There is a gap in between the dash and glove compartment where the stereo should be and I am presuming there should be a stereo 'housing' of some sort there and this is missing. Can I get one anywhere? Many thanks Mick Mick, I have an uncut dash for sale £35. No sun damage to the top either, in excellent condition. If interested let me know. Paul 07958 579628 Link to comment Share on other sites More sharing options...
