Chris M Posted September 13, 2009 Share Posted September 13, 2009 Hi I need a replacement rear speaker in grey for my GTE coupe. The paper cone inside has split on mine so it sounds poor. If a pair are only available then that's ok. Thanks Link to comment Share on other sites More sharing options...
Beaker Posted September 15, 2009 Share Posted September 15, 2009 Can you post/send a picture or give dimensions. If you get stuck paper cones can be fixed with masking tape and then painted over to strengthen. This technique has been used on pa/music speakers for years and a similar principle worked for the wings of aircraft back in the 30's. If the cone surround is made of cloth and has split the same technique will work. Neoprene rubber cone surrounds have to be replaced though. Link to comment Share on other sites More sharing options...
Chris M Posted September 16, 2009 Author Share Posted September 16, 2009 Thanks. I will try that if I don't get any response. Link to comment Share on other sites More sharing options...
Chris M Posted September 27, 2009 Author Share Posted September 27, 2009 Still looking for rear speaker's off coupe, surely soeone must have at least one. Not bothered about colour and not bothered about a pair. Cheers Link to comment Share on other sites More sharing options...
cam.in.head Posted September 27, 2009 Share Posted September 27, 2009 i presume you have the plastic casing & just req a speaker to go in it. any car acc shop should be able to supply ones to fit in. best replacing both thou. or maybee maplins.also plenty on ebay just need diameter Link to comment Share on other sites More sharing options...
Chris M Posted September 27, 2009 Author Share Posted September 27, 2009 Tried that and unfortunately most of the aftermarket speakers available in that diameter are too deep for the Manta plastic casing. Thanks for response. Still looking! Link to comment Share on other sites More sharing options...
