upk Posted September 18, 2009 Share Posted September 18, 2009 hi all, following my recent experience with intermittent brake loss i have found the culprit. a damaged seal in the master cylinder!! can anybody help with a new seal kit or point me in the right direction?? ate 20mm diameter think the master cylinder is the same as the gte but the fluid resovoir bottle in the photo was off my 'A' so dont let that confuse you. ta kev (aka upk) Link to comment Share on other sites More sharing options...
paulmanta Posted September 18, 2009 Share Posted September 18, 2009 You need to talk to Pastparts, they rebuild master cylinders and have just done one for me. they are good, they relined one and resealed it for my Ascona and i had it back quickly, t did cost £100 though. Brakes are pretty critical though, its a pest if the car does not start but lethal if it does not stop. http://www.pastparts.co.uk/reman.htm Link to comment Share on other sites More sharing options...
upk Posted September 18, 2009 Author Share Posted September 18, 2009 thanks paul may chase that lead up. if i can get a seal kit i can fix it, does anybody know the ate seal kit part number?? Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted September 22, 2009 Share Posted September 22, 2009 I believe that you are looking for 1605245 KIT INNER PARTS MAIN CYL.20MM ATE (REPL 1605550-522-111-226-434-523) REKORD/C-D-E-ASCONA-MANTA/ALL-KADETT/B-KADETT/C If you will not find it...........available at 40 Link to comment Share on other sites More sharing options...
