robg88 Posted September 22, 2009 Share Posted September 22, 2009 I'm after an A series rear axle, located in north wales but willing to travel. Thanks, Rob. Link to comment Share on other sites More sharing options...
rutts Posted September 22, 2009 Share Posted September 22, 2009 why not just drill out the welds where theaxle tubes fit into the diff casing cut down the tubes and reweld. take drive shafts to engineers get spline cut longer onto drive shaft cut down to suit, a series axles are getting quite rare now. Link to comment Share on other sites More sharing options...
blitzi Posted September 25, 2009 Share Posted September 25, 2009 why not just drill out the welds where theaxle tubes fit into the diff casing cut down the tubes and reweld. take drive shafts to engineers get spline cut longer onto drive shaft cut down to suit, a series axles are getting quite rare now. i have one m8 but am in scotland but chris is coming up from s wales with parts for me i could see if he maybe take it down for u m8 Link to comment Share on other sites More sharing options...
robg88 Posted September 26, 2009 Author Share Posted September 26, 2009 i have one m8 but am in scotland but chris is coming up from s wales with parts for me i could see if he maybe take it down for u m8 Is that a manta b axle? Cheers, Rob Link to comment Share on other sites More sharing options...
blitzi Posted September 26, 2009 Share Posted September 26, 2009 Is that a manta b axle? Cheers, Rob no its a manta a axle m8 but it was only a 1.3 engine in the car so it might be a low ratio Link to comment Share on other sites More sharing options...
robg88 Posted September 26, 2009 Author Share Posted September 26, 2009 How much would you want for the axle? Is it complete with the steel torque tube? Cheers, Rob Link to comment Share on other sites More sharing options...
Robbie Posted September 26, 2009 Share Posted September 26, 2009 How much would you want for the axle? Is it complete with the steel torque tube? Cheers, Rob Its prob the smaller axle then, the normal 1900 manta A axle is the exact same as the B only narrower. Link to comment Share on other sites More sharing options...
blitzi Posted September 26, 2009 Share Posted September 26, 2009 Its prob the smaller axle then, the normal 1900 manta A axle is the exact same as the B only narrower. no torq tube was hit by f liftwhen strippin car m8 Link to comment Share on other sites More sharing options...
