mickappy Posted September 30, 2009 Share Posted September 30, 2009 due to bonnet lifting after forgetting to put fasten pins im in need of a scuttle panel and bonnet hinges in good nick. Link to comment Share on other sites More sharing options...
mantasrme Posted September 30, 2009 Share Posted September 30, 2009 due to bonnet lifting after forgetting to put fasten pins im in need of a scuttle panel and bonnet hinges in good nick. I've got a scuttle panel that i chopped out of an old coupe a few years back, was in good condition from memory. I'll get it down from the garage roof and give it a check over tomorrow. Don't have hinges though as i used them when my bonnet did the same as yours good job i had hyd struts on as it stopped the bonnet from getting to the screen/roof. Link to comment Share on other sites More sharing options...
spiney_norman Posted October 1, 2009 Share Posted October 1, 2009 Might have some bonnet hinges, I'll let you know ASAP Mick. Link to comment Share on other sites More sharing options...
mickappy Posted October 1, 2009 Author Share Posted October 1, 2009 cheers guys. having looked this morning the bonnet is near perfect and can easily be fixed. the hinges have had it and the scuttle panel is twisted up and might be possible to save. how the hell do u change the hinges??? i can always chop em off and go for 4 bonnetpins? anyone done this? Link to comment Share on other sites More sharing options...
Robbie Posted October 1, 2009 Share Posted October 1, 2009 Hinges are a shitty wee job, they are put on with like a rivet, grind the heads of and put the new ones on with shouldered bolts with lock nut. From memory I had to ream the hole out, the rivet may have been stepped, cant rem 100% Mick but it wasn't my fav job at the time lol Link to comment Share on other sites More sharing options...
mantasrme Posted October 2, 2009 Share Posted October 2, 2009 Here's a pic of the scuttle panel i have, there's a very small bit on the OS thats rusted through At each side its a bit rusty on the under side but you can access it to clean up and treat and its not gone through anywhere else. Its complete with the brackets underneath and part of the box section that runs across behind the dash (chopped it out like this to keep the strength/shape while storing it) So it can easily be cleaned back and the spot welds drilled out to leave just the scuttle panel or just chop out the end sections and graft them in to replace your bent parts I'm only over in Harrogate and want £5 for it if your interested Link to comment Share on other sites More sharing options...
mickappy Posted October 2, 2009 Author Share Posted October 2, 2009 cheers for that mate, having looked more the day after the accident ive decided it will be alot easier to fix than replace. all im short on is the hinges. thanks again Link to comment Share on other sites More sharing options...
