Xe Conversion In To Manta A
stuart h
Hello all can anyone help locating the rare xe conversion parts to fit the xe in to manta A
some parts i know i can get new
1.8 gearbox, AQUIRED
sump (can get yukspeed one) AQUIRED
rwd manifold (can get new)
DCOE inlet manifold (can get new) AQUIRED
simhammond@gmail.com
07970800585
Edited by stuart h
What else do you need, need a few more details. How are you doing ignition??? If you are using a manta 1800 dizzy then I have a full setup spare off a 1.8, £50
I have some 1.8 engine mounts, you'll either need those or some steel ones making up. I want £40 for the pair I have.
Clutch bits, best bought new
Most of the rest comes with the engine. You'll need a 1.8 manta oil pickup pipe, or mod the 16v one, sorry don't have any spare, all mine are lined up for jobs now!
If you are stuck for any XE16v bits I have plenty of spares
Edited by Retro Power
thanks for your reply
I might need the mounts not sure yet I have got two triangle plates that fit the block so I might make them
I'm going to use megajolt for the spark's
iv got three ex engines so I hopefully should be ok
