Complete 16V Conversion Parts Inc. Engine
simon p
Everything you need to convert your Coupe to 16v power. From the radiator to the exhaust tip, will fit a hatch with exhaust system mod. Really drives well, engine only covered 65000 miles. The complete setup is still in the car so you can come and try it first. £1000. If you add up the cost of all the parts, you'll know you're on a winner, especially if you consider you can see it working and isn't 'under a bench' or 'was running great when removed' if you know what i mean.
I know you're saying everything from rad to exhaust tip, so i guess i'm right in assuming that it includes:
Rad, hoses, engine (complete), gearbox, prop, full loom harness, GT/E tank, fuel pump........everything to go 16v injection?
Could be interested and so really want to know what's there and what isn't.
BTW is it a dizzy-less engine?
i would say as its a PT ecu, it is a late dispak engine.
Hi mate, yes everything you listed. Lepo5's correct too, its a coil pack setup. Also got a set of twin 45 webers and manifold to fit the XE, £500ish for that
Hi Have you sold your engine yet. If not where are you in the country?
