Fuel Pump Relay Wanted
Mrbus
Cant say anymore. Car was fine earlier. Went to start car, it started for a sec then died. Cant get fuel pump to work so im guessing its the relay as i remember someone saying that they always pack up
u can still get these new m8 from any good auto electricians they are about £28.00 including the vatthumbsup.gif
Yeah i know. Just fought that £26 was a bit much for a relay. Tried the knocking trick hoping but still nothing. At least im pretty certain that this is the problem.
have you tried the fuse .....
no 7 if my memory still works
Yep, tried that. Just have to wait until my relay turns up. Local motor factors wanted £40 plus the vodka & tonic
Got one off ebay for £27
The fuel pump runs through fuse 7 on a GTE, and those of you who have tried will know you can pull every fuse out of the box but 7 and a Manta will still run.
So what's the point? Well if your injection relay goes you can usually limp home like this, a copper coin bridges either fuse 6 or 8 to 7 to power the fuel pump. Leave the injection relay in place when doing this or the injection won't run.
Other uses:
Ran out of fuel and don't want to flatten the battery cranking while you wait for pressure
Emptying the tank / flushing new pipes
Finding out which is the feed if you don't trust going by pipe position
Some muppet connected an imobilizer / cut out switch badly
Fuel pump live will back feed to ignition, so you can pull the key out and leave the car running
Downsides, if its a poor connection the coin can get hot so don't melt the fuse box
No warranty implied or given.....
Other uses:
Ok so i did this coin trick & it started. I take it that is defo my fuel relay that needs replacing then?
What you've proven is the car isn't running the fuel pump without a coin in place.
The most common cause of this and easiest to test is the fuel relay.
You could potentially still have a wiring fault but I've not seen it come to that yet.
If you have a look at the wiring diagram on the relay to see the switched terminals you should be able to prove a live exists and also check continuity with a volt lamp or meter as far as the fuse, but to be honest not worth the effort till you have a relay and once you have one probably won't be a problem.
Save the old one, might be interesting to get to the bottom of the fault sometime.
