Electric Windows
jasonpirtek
I know a bit about this!
My first Manta SR had a set fitted by me. Providing the windows are fitted adjusted and lubricated properly they work fine. Don't expect them to whizz up and down like a modern, they are slow by comparison.
My car had a console mounted switch from a mk2 cavalier to give it a "factory" look. Modding the wiring is relativley easy to go from a 3 switch to 2 switch set up.
I also have a set on the Strada Cabrio that I currenty own.
If you search around (I used German ebay) and go for a spal set or a quality kit they do (or used to do) two levels of kit, the more expensive kit being a bit more.
Haven't bought a set for 4 years so I might have a surf and come back here.
Fitting is quite easy too, I rubber mounted the motors to isolate the noise
They are a tight fit in an A series door. not sure if I'll just be sticking with handle winder or not now.
thanks for the heads up, might give them a go. cheers
