daisybump Posted July 8, 2010 Share Posted July 8, 2010 Does anyone know if this is a straightish swop or am i waisting my time, i had read somewhere it was an easy swop, but can't seem to find any info anywhere.. Quote Link to comment Share on other sites More sharing options...
costasa Posted July 8, 2010 Share Posted July 8, 2010 Hi, from what i read is a straight swap and you can search here or in opelgt.com forum info about the LSD If you search in the quaife site the lsd that they offer to manta and gt is the same as they offer to the isuzu. Good luck Quote Link to comment Share on other sites More sharing options...
rutts Posted July 9, 2010 Share Posted July 9, 2010 you must use a series axle casing and use izusu shafts as they are splined different than mantas. or get shafts made to fit. Quote Link to comment Share on other sites More sharing options...
daisybump Posted July 9, 2010 Author Share Posted July 9, 2010 If its gonna get complicated i might be better off selling it and buying a gripper lsd me thinks.. Quote Link to comment Share on other sites More sharing options...
bones Posted July 12, 2010 Share Posted July 12, 2010 Piazza diff comes out the front of the axle casing rather than the rear like a Manta one. Will it fit?? Quote Link to comment Share on other sites More sharing options...
16VManta Posted July 13, 2010 Share Posted July 13, 2010 It's 4 linked as standard. I've not put mine next to my manta to see if the lower arms go near the chassis mounts, but the upper arms will need something fabricating. You would also need a new prop making. Quote Link to comment Share on other sites More sharing options...
young kadett kinin Posted July 15, 2010 Share Posted July 15, 2010 (edited) in a kadett/chevette the lower arms are an inch shorter(i'v measured) . I always thought that the lower arm location was similar between kadett c/chevette/manta a/b/gt/cavvy mk1. The top arm needs a link box made which will poke up into the rear seat area(in a kadett c saloon anyway). Edited July 15, 2010 by young kadett kinin Quote Link to comment Share on other sites More sharing options...
