mantapaperman Posted September 18, 2010 Share Posted September 18, 2010 hi. anyone know if any of the following are the same? manta 1.8 hatch propshaft and a 2.0 gte coupe propshaft. bothe five speed and the only thing that looks differant is the springs inside the box end of prop? and does it matter which spring you use? thanks in advance.. Quote Link to comment Share on other sites More sharing options...
mark morris Posted September 18, 2010 Share Posted September 18, 2010 When i fitted a 16v to my old gte i used the same prop, no probs Mark Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted September 18, 2010 Share Posted September 18, 2010 same ends on but they are different sizes I think the longer one is the 1800 Quote Link to comment Share on other sites More sharing options...
mantapaperman Posted September 18, 2010 Author Share Posted September 18, 2010 thanks very much for the pics and replys. i,m fitting a 2.0 sri 130 engine. so i've fitted the a 1.8 gearbox out of a hatch i broke, and was wondering if i should fit the hatch prop? the propshaft on the gte coupe i've fitted engine and box in seems to fit up ok. but you can see it doesnt go as far in? in theory it shud be same as a c20xe block job? therefore the coupe prop shud be ok you think? with bigger spring in end..sorry to babble chaps. Quote Link to comment Share on other sites More sharing options...
