Goose Posted October 5, 2010 Share Posted October 5, 2010 I require a petrol tank for my 1984 Manta GTE Hatch. Will the petrol tank from a standard hatch or coupe fit or does it have to be from a GTE Hatch? Im locaterd in Dunblane Scotland, just round the corner from Rab. Link to comment Share on other sites More sharing options...
spiney_norman Posted October 5, 2010 Share Posted October 5, 2010 The coupe tank's completely different, they fit inside the boot. A hatch tank for a car with a carb can be made to fit, you just need to add a fuel return. Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted October 6, 2010 Share Posted October 6, 2010 You can use the 1.2 or 1.6 tank BUT with the same type of chassis like yours (from hatch to hatch and from coupe to coupe)! You have to replace the output hose of 8mm to 12mm and the return can be done to the upper hose of ventilation to 8mm If you will use the same output 8mm the fuel pump (since it will have less/equal flow than pressure)will be damaged VERY soon (will start from making noise till......it will die!!) Link to comment Share on other sites More sharing options...
Rab Posted October 6, 2010 Share Posted October 6, 2010 (edited) Hello Goose. Hiv awe word wi `Blitzi` on here, Wullie may have one lying around, worth a chat to. cheers rab. or. http://forums.mantaclub.org/topic/26694-gte-hatchback-injection-petrol-tank/ Edited October 7, 2010 by Rab Link to comment Share on other sites More sharing options...
Goose Posted October 8, 2010 Author Share Posted October 8, 2010 Cheers for the help. My mate is going to try and repair thr old tank first unless a good one turns up in the meantime. Im off to Turkey this week so will post update when i get back. Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted October 9, 2010 Share Posted October 9, 2010 Cheers for the help. My mate is going to try and repair thr old tank first unless a good one turns up in the meantime. Im off to Turkey this week so will post update when i get back. FUEL TANKS HAVE TO BE CLEANED WITH TOO MUCH WATER AND THE MAN WILL KNOW THE RULES FOR SOLDERING FUEL TANKS......so be carefull!!!! Link to comment Share on other sites More sharing options...
mantadoc Posted October 9, 2010 Share Posted October 9, 2010 Put hatch in the title to improve your chances. Frost do products to repair and seal porous tanks without welding. Link to comment Share on other sites More sharing options...
Goose Posted October 19, 2010 Author Share Posted October 19, 2010 Removed tank and cleaned but too far gone to repair so need replacement. Any still available? Cheers Goose Link to comment Share on other sites More sharing options...
hedcase Posted November 20, 2010 Share Posted November 20, 2010 I think Northern Radiators make new tanks. You can find them on the web. Link to comment Share on other sites More sharing options...
cam.in.head Posted November 20, 2010 Share Posted November 20, 2010 yes try northern radiators. not sure about getting a new tank but they can do a process called RENEW. this has a lifetime guarantee i think. definately worth a phone call. Link to comment Share on other sites More sharing options...
