MickB Posted October 6, 2010 Share Posted October 6, 2010 Hi, I have a weber twin choke carb fitted to my '74 A and I am not sure which air filter unit will fit. Currently it has a piece of cut out sponge fitted to it. I know the original circular type units do not fit so was wondering if anyone could recommend something. Picture below of carb. Many thanks Mick Quote Link to comment Share on other sites More sharing options...
rayman Posted October 6, 2010 Share Posted October 6, 2010 Hi check this out on ebay 400160589528 it is a member on here Ray70 and it has an adaptor to fit it to the weber so looks standard .. Quote Link to comment Share on other sites More sharing options...
MickB Posted October 6, 2010 Author Share Posted October 6, 2010 Rayman, many thanks. Mick Quote Link to comment Share on other sites More sharing options...
ray70 Posted October 6, 2010 Share Posted October 6, 2010 Hi, I have a weber twin choke carb fitted to my '74 A and I am not sure which air filter unit will fit. Currently it has a piece of cut out sponge fitted to it. I know the original circular type units do not fit so was wondering if anyone could recommend something. Picture below of carb. Many thanks Mick Hi again Mick, You just asked me a question on ebay, your carb looks like its the same as the one on my Manta. Thanks, Ray. Quote Link to comment Share on other sites More sharing options...
MickB Posted October 6, 2010 Author Share Posted October 6, 2010 Great, looks like I could be well interested in the unit then. I presume there is enough space between carb/air filter and bonnet once it is fitted ? Regards Mick Quote Link to comment Share on other sites More sharing options...
costasa Posted October 7, 2010 Share Posted October 7, 2010 (edited) Hi, Another option is this http://www.carbureti...berpartsair.asp Don't look original but will give another look to your engine And some times this apear in ebay at good prices. Edited October 7, 2010 by costasa Quote Link to comment Share on other sites More sharing options...
ray70 Posted October 7, 2010 Share Posted October 7, 2010 Great, looks like I could be well interested in the unit then. I presume there is enough space between carb/air filter and bonnet once it is fitted ? Regards Mick Hi again Mick, Yes it leaves enough clearance for the bonnet, will you need the pipe that goes from the rocker box to the underside of the air filter to, if so let me know? Thanks, Ray. Quote Link to comment Share on other sites More sharing options...
