mantapaperman Posted October 22, 2010 Share Posted October 22, 2010 anyone know the best oil to use in the following...1.8 gearbox and a gte axle..dont have a manual..thanks in advance.. Quote Link to comment Share on other sites More sharing options...
blitzi Posted October 22, 2010 Share Posted October 22, 2010 syinthetic bud as it preserves the life of your g/box! Quote Link to comment Share on other sites More sharing options...
mantapaperman Posted October 22, 2010 Author Share Posted October 22, 2010 is it EP 90 in both ??? what grade etc? Quote Link to comment Share on other sites More sharing options...
blitzi Posted October 22, 2010 Share Posted October 22, 2010 what i can recall its full syn i got it at local v/hall garage told them it was for a getrag box and it wasnt any more expensive than a local motor factors coz once u change the oil it will do at least five years due to alot of manta owners not doing alot of miles!! Quote Link to comment Share on other sites More sharing options...
hedcase Posted October 22, 2010 Share Posted October 22, 2010 I also use the vauxhall synthetic gearbox oil, the smelly red stuff, and it's fine. For the GT/E axle, I use Castrol's Driveline syntrax. Quote Link to comment Share on other sites More sharing options...
eldoradoCoupe Posted October 22, 2010 Share Posted October 22, 2010 75W90 grade is whats recommended in my haynes manual Quote Link to comment Share on other sites More sharing options...
Rick-Manta Posted October 22, 2010 Share Posted October 22, 2010 (edited) I use Castrol SMX-S (which is fully synth 75w/90) in the boxes and Castrol Driveline Syntrax in the diffs. Although it should be noted; I have been told by a couple of club members that the red cherry smelling stuff from vauxhall should only be used in getrag boxes. I'm pretty certain it's an ATF with an additive as there's certainly nothing magical in it to make it special and besides the castrol SMS is the recommended gearbox oil for my chevy which has the same gearbox you'd find in a FWD redtop'd car which vauxhall dealers put the cherryade stuff into. I'm not suggesting you'd be this silly but I have known some to use it in modern boxes...DO NOT USE HYPOID! Edited October 22, 2010 by Rick-Manta Quote Link to comment Share on other sites More sharing options...
eldoradoCoupe Posted October 22, 2010 Share Posted October 22, 2010 Just realised my mistake, the diff is EP90, 75W90 is the box. Quote Link to comment Share on other sites More sharing options...
manta400john Posted October 22, 2010 Share Posted October 22, 2010 COMMA SX 75W-90 GL5 spec for the box. EP 90 + sawdust for the diff. This topic is covered well in members tech. bit........well worth the money. You can join the OMOC today! John. Quote Link to comment Share on other sites More sharing options...
mantapaperman Posted October 23, 2010 Author Share Posted October 23, 2010 thanks for the info everybody..now sorted.. EP90 in diff and 75w90 in box..the diff seems to whine i little now? maybe it had some molyslip in it..i,ve changed it so maybe will have to add some more? cheers again Quote Link to comment Share on other sites More sharing options...
Rick-Manta Posted October 23, 2010 Share Posted October 23, 2010 You should note when referring to manuals that the modern synthectic gear oils didn't exist when they were published. Lubricants we can get nowadays can and will work better than the stuff we had 20 years ago. Quote Link to comment Share on other sites More sharing options...
MANTAMAN Posted October 28, 2010 Share Posted October 28, 2010 As i was told a long time ago, you must only use the genuine GM oil in Getrag gearboxes, (the red 'cherryaid' stuff) If you joined the club you can get it cheap, as the Manta Club is affiliated to the Vauxhall - Bedford - Opel association we all get stuff like this at trade price over the counter at Vauxhall dealers. Quote Link to comment Share on other sites More sharing options...
