Ascona 2 Door Conversion Parts
gt4_ade
Sounds like a bit job and obviously to do it you're going to have to cut the original B pillar out so why not just move it back 6 inches (or whatever the difference is). Cut a section out of the rear door and weld into the middle of the fronts thus lengthening them and then weld the remains of the rear door in the rear. then all you need is the 2dr glass :thumbup
interesting one this.
I would start off with a Manta sill and weld in place.
Manta door is the same as what was fitted on the 2 door MKI Cavs and Scones, will need to cobble up the door frame from 2 of the Scone doors.
With sill and door in position, there should be a good starting point for the B pillar and quarter panel dimensions/positioning/modification.
Well they were my first thoughts on tackling this, seems pretty straightforward at first............
At the end of the day the cars are only made of steel, and you can do anything with steel.
unfortunately you're onto a loser here.
The bits you need will have to come from a 2 door shell, and whatever condition that's in, it will be easier to restore it than convert a 4 door!
2 doors are the rarest opels in the uk now, think there are 7 left on the road according to dvla, they are right at the top of the endangered list!
Get a 2 door shell from germany, and use your 4 door front end parts to convert it to RHD if you want.
RHD 2 doors are like hens teeth
Endangered yes but i think your figures may be wrong..... reason being if your figures are correct then i own roughly 80% of those remaining 7, and know of at least another 10- 15 rhd 2 doors UK registered (not converted Mk1 Cavaliers) but not sure if these ones are taxed or sorned.... and not sure what way the dvla records work.
Know of another guy in southern Ireland who bought a back section of a 2 door in Germany along with two doors (2 door ones) and converted the panels from a 4 door to a 2 door so it has been done before.
Still think cheaper option is to buy a lhd one in the first place, though as said 2 door Asconas in rhd form are getting thin on the ground.
Will disagree with you there Nat, or Callum.
Anyone that is used to cutting and welding should be able to do a competent job of the transformation from 4 to 2 door.
Only real 2 door parts that would be needed as far as I can see would be headlining and front and rear cards to match whatever interior trim oh and maybe some 2 door rear quarter glass and seals, hmm seeing a slightly bigger picture now, now a bit more thought is going into it
Edit:-
Bit more thought.....
hardest part ofany fabrication would be to do a nice job of modding the complete 'B' pillar, especially where the rear quarter glass would be fitting.
Also you would be needing to find longer door seals for the 2 door, manta ones will be different due to lack of window frame on the manta obviously.
The more I think the more the steel work seems the easiest bit.
Edited by opel2000
Been chewing this over in my head a bit more............
Won't the rear quarter glass frames/seating/mounting area not be there as there will be an aperture for a door instead.
Can see this causing quite a few problems......
Looking at this area this could cause one hell of a serious headache. Personally I would not like to be fabricating an area such as this myself, this would be really difficult, even if there was a drawing to work from.
I know this would be a hell of a lot of work but if i imported a 2 door from germany i don't know what the car would really be like, were as i know my 4 door only has 1 owner, 43k and waxolyed from new so under neath it is soild. If i could get a lhd 2 door that was sturctally sound i think i would end up making a rhd 2 door out of the 2 cars.
Edit:-
I don't fancy making the upper b pillar from scratch and getting no distortion in it!!
Yea I think the DVLA figures are ones currently taxed.
I got that number from Total Vauxhall Mag "endangered list" article a few months back, and they got it from DVLA
PS not too shy of bit of metalwork..........Retropower ascona 400R build
Edited by Retro Power
I've a mint white 2 door lhd Ascona coming home from Holland fairly soon which i will be selling, i'll keep you informed.
See the way i would look at it if i were you is that your four door is worth, for talks sake £1500. Why if its so good would you cut the bulkhead out of it when you can buy a bulkhead and all dash parts out of a rotten one for £150. And a little more than £2000 will get you a good lhd home from abroad. I converted a lhd to rhd last year, had the dash etc etc and the panel beater charged me £200.
So basically if you buy the colour in lhd that you want, you should have it converted into rhd including painting bulkhead for say under £3000.
So for talks sake £1500 on top of the four door if you sold her... though these figures are just gestimates, also i don't know what your 4 door is worth so just using £1500 as a figure.
So there ye go........
Brian/ ascona400r,
It would be interesting to start a register of these Asconas with pictures and info on if they are 400 replicas / arched / unarched /standard / modified etc.....What do you think? Luke.
Edited by 399Road
