Kevin Abbott Posted February 12, 2011 Share Posted February 12, 2011 Dump those drums! Rear disc conversion cw discs, bolts and k nuts, caliper brackets, uprated long studs and fitting instructions. You need a pair of ford rear calipers ( cosworth, sierra, granada etc ) and we can arrange pipe work but that is easy to do. This is all bolt on so when you blow up the standard glass manta diff you can put it onto another £175 plus p+p Loads of high power and concours Mantas in the club have my kit with no problems what so ever, the disc slides over the new studs and the wheel holds the disc on as in most modern cars, even Nick in the USA has one of my kits on his car ;) Quote Link to comment Share on other sites More sharing options...
rayman Posted February 12, 2011 Share Posted February 12, 2011 Oh Kev they look pretty,if only i hadn't just bought new drums etc Quote Link to comment Share on other sites More sharing options...
mantasrme Posted February 12, 2011 Share Posted February 12, 2011 Out of interest what handbrake cable do you nned to run on these? Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted February 12, 2011 Author Share Posted February 12, 2011 Out of interest what handbrake cable do you nned to run on these? Standard manta cable slightly rerouted or a short sierra one that involves a little head scratching I used the manta one for 2 years with no problems and the rear caliper are good as long as you keep on top of the maintenance Quote Link to comment Share on other sites More sharing options...
2908642343 Posted February 12, 2011 Share Posted February 12, 2011 Have been using this set up for 3+ yrs now on my Manta without any problems at all. Have used the Manta hand brake cable and not had one single problem with the set up. John Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted February 14, 2011 Share Posted February 14, 2011 Would mk3 mondeo rear calipers/carriers work? Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted February 14, 2011 Author Share Posted February 14, 2011 Would mk3 mondeo rear calipers/carriers work? Not sure if they are the same caliper, mk3 mondeo calipers are supposed to be a bit of a pain in the a&&e Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted February 15, 2011 Share Posted February 15, 2011 Ahhh I've got a couple of pairs you see A disk conversion is tempting still........... Quote Link to comment Share on other sites More sharing options...
