msymonds77 Posted February 24, 2011 Share Posted February 24, 2011 Hi, i'm looking for a Red Opel Manta from 1982 onwards. I need one in pretty good condition, minimal rust probs and def no welding needed, not fussed about how many owners as long as they have been kind I'd prefer it with at least 6 months MOT, and if any tax on it then all good. I am based in London but will travel for the right car. I don't really have a budget as it depends on the condition and model but don't take that as me being made of cash. Reason for buying is my family used to rally them back in the day and i've been looking for the right one for a while now but no joy so far........ so if there is anyone selling please get in touch. thanks Melanie Link to comment Share on other sites More sharing options...
mantadog Posted February 24, 2011 Share Posted February 24, 2011 welcome this is defo the place to find what your looking for!! what type are u after coupe or hatch? good luck with the hunt!!! Link to comment Share on other sites More sharing options...
bettyswallox Posted February 25, 2011 Share Posted February 25, 2011 I have a red Manta Hatch GT/J It needs minimal welding ( as per the failure sheet = seat-belt anchorage points ) NO mot or tax ... Could be the bargain your looking for .... PM me thru' this forum Best of luck with your search .. Link to comment Share on other sites More sharing options...
msymonds77 Posted February 26, 2011 Author Share Posted February 26, 2011 welcome this is defo the place to find what your looking for!! what type are u after coupe or hatch? good luck with the hunt!!! thanks! don't mind either, more bothered about condition as i need to be able to use it straight away, i'm looking at one...83 coupe but its got a bit of rust round the sun roof which is making me a bit wary.......any thoughts welcome Link to comment Share on other sites More sharing options...
mantasrme Posted February 26, 2011 Share Posted February 26, 2011 Rusty sunroofs are very common and are not easy to fix properly. The sunroof tray has a foam strip between it and the roof panel, over the years this absorbs moisture and water from the sunroof tray This then slowly starts to rust the under side of the roof and eat its way through to the outside. By the time you see it the rust is very well established and can't just be rubbed down and treated from the outside stripped a rusty manta hatch last month and while there were only 2 small spots just starting to show on the roof This is what it looked like inside when i chopped the panel off The outer thick line is where the foam was around the tray If you remove the roof lining you could go around most of the tray and scrape away the foam and treat the metal But once its popped through on the outside you'll really need to weld a patch in. Of course then it wants paintng, and to fit a new roof lining all the glass needs removing and the rubber trims around The way i see it with that amount of work you might aswell remove the sunroof completely and plate the hole That way you know it'll never be a problem again Link to comment Share on other sites More sharing options...
adz the stig Posted February 28, 2011 Share Posted February 28, 2011 http://belfast.gumtree.com/belfast/18/71338218.html this is what you want. look perfect to me well worth the travel. Link to comment Share on other sites More sharing options...
keith1200 Posted February 28, 2011 Share Posted February 28, 2011 (edited) A cheaper and really easy way is to fit a glass sunroof! however If your rallying etc you'd be better going with mantasrme's idea I fitted one afew years back! cost: £4 for a fine metal cutting jig-saw blade and a glass sunroof for a £10 spot from the scrap-yard and a good day's work Edited February 28, 2011 by keith1200 Link to comment Share on other sites More sharing options...
msymonds77 Posted March 3, 2011 Author Share Posted March 3, 2011 Rusty sunroofs are very common and are not easy to fix properly. The sunroof tray has a foam strip between it and the roof panel, over the years this absorbs moisture and water from the sunroof tray This then slowly starts to rust the under side of the roof and eat its way through to the outside. By the time you see it the rust is very well established and can't just be rubbed down and treated from the outside stripped a rusty manta hatch last month and while there were only 2 small spots just starting to show on the roof This is what it looked like inside when i chopped the panel off The outer thick line is where the foam was around the tray If you remove the roof lining you could go around most of the tray and scrape away the foam and treat the metal But once its popped through on the outside you'll really need to weld a patch in. Of course then it wants paintng, and to fit a new roof lining all the glass needs removing and the rubber trims around The way i see it with that amount of work you might aswell remove the sunroof completely and plate the hole That way you know it'll never be a problem again yikes! thanks for the advice.....m Link to comment Share on other sites More sharing options...
1900SR Posted March 5, 2011 Share Posted March 5, 2011 Have you seen this one, from the advert looks to be good 1.8 hatch. http://forums.mantaclub.org/topic/26943-manta-18s-gtj-hatch/ Link to comment Share on other sites More sharing options...
msymonds77 Posted March 9, 2011 Author Share Posted March 9, 2011 Have you seen this one, from the advert looks to be good 1.8 hatch. http://forums.mantac...-18s-gtj-hatch/ yes but sadly they decided not to sell, i think they were shocked someone finally made them an offer! Link to comment Share on other sites More sharing options...
deanosabby Posted March 9, 2011 Share Posted March 9, 2011 Don't know if this is your cup of tea but I am selling my Cavalier Coupe. http://forums.mantaclub.org/topic/27880-1978-mk1-cavalier-coupe-in-red/ Bit older than you are looking for. Ta, Deano. Link to comment Share on other sites More sharing options...
i200_pete Posted April 18, 2011 Share Posted April 18, 2011 Hi, very nice low milage Red Hatch on here now in cars for sale. Coming up in May. Club Member Owner. Pete. Link to comment Share on other sites More sharing options...
Fc4ster Posted April 20, 2011 Share Posted April 20, 2011 Hi, http://forums.mantaclub.org/topic/28260-18-berlinetta/ My 1.8 Red Berlinetta is for sale in the cars for sale section, Based near Langholn (Scottish Borders). Thought it might interest you. Chris Link to comment Share on other sites More sharing options...
andyc Posted May 20, 2011 Share Posted May 20, 2011 How about this, local to me and have seen it but not a good look over http://www.pistonheads.com/sales/2777500.htm Andy Link to comment Share on other sites More sharing options...
Kevin Abbott Posted May 20, 2011 Share Posted May 20, 2011 How about this, local to me and have seen it but not a good look over http://www.pistonheads.com/sales/2777500.htm Andy Holy shit that is a good looking exclusive, i want a lot Link to comment Share on other sites More sharing options...
couperman Posted May 23, 2011 Share Posted May 23, 2011 Now sold - who bought it??? Link to comment Share on other sites More sharing options...
MikeyRules Posted May 25, 2011 Share Posted May 25, 2011 I nearly went to see this as it looked superb on paper,(was in Southend on sea) and the guy was a genuine enthusiast who certainly knew his Manta's. I think from memory it had a few rust bubbles just starting aound the sunroof and a couple of things to make mint. Link to comment Share on other sites More sharing options...
