Omega R25/28 To C20Xe Clutch Slave Spacers
Retro Power
  • 3 months later...
I am fitting an R25 box to an XE, I have fitted a hydraulic slave cyliner from an Omega therfore converted from the original Cable (B4 you ask, it is so that I can keep the mud out of the bell housing as I can use bulhead fittings for the hydraulic pipes) I want to use a flat flywheel and assume therfore that this is the spacer I need.
ORR
ORR
yep, this is what you need ;)
  • 2 months later...
  • 8 years later...
  • 1 year later...
