Scribe of Lincoln Posted April 3, 2011 Share Posted April 3, 2011 Does anybody have a Brake Master Cylinder for a 1976 Manta B in good condition please? Alternatively if anybody has a new Master Cylinder I would be interested. Cheers, Scribe Link to comment Share on other sites More sharing options...
E416 PBO Posted April 3, 2011 Share Posted April 3, 2011 Saw a new one on Ebay roughly a month ago! Probably your best bet Does anybody have a Brake Master Cylinder for a 1976 Manta B in good condition please? Alternatively if anybody has a new Master Cylinder I would be interested. Cheers, Scribe Link to comment Share on other sites More sharing options...
casper1483 Posted April 3, 2011 Share Posted April 3, 2011 Take your old one to bits keep an eye on the order that the seals and washers are in and the way the seals are facing and check the condition of the inner cylinder if its ok measure the internal diameter and give big red a call thier on fliebay , they supplied mine about £20, they were delivered two days later and my master cylinder on my 76 is like new....................... Link to comment Share on other sites More sharing options...
Scribe of Lincoln Posted April 3, 2011 Author Share Posted April 3, 2011 Take your old one to bits keep an eye on the order that the seals and washers are in and the way the seals are facing and check the condition of the inner cylinder if its ok measure the internal diameter and give big red a call thier on fliebay , they supplied mine about £20, they were delivered two days later and my master cylinder on my 76 is like new....................... Thanks for the advice. I'll try this if I can't find an exchange unit. Link to comment Share on other sites More sharing options...
Joe Posted April 3, 2011 Share Posted April 3, 2011 I've got a new cylinder you can have for £40 delivered if that will do the trick Ben? It doesn't come with the reservoir but it is brand new old stock (made by 'Moprod' if I recall correctly.) Send me an e-mail and we'll take it from there if you're interested. All the best, Joe. Link to comment Share on other sites More sharing options...
mantadoc Posted April 3, 2011 Share Posted April 3, 2011 Always remember to check for matching double or single flare on the front right brake pipe at the master end. Link to comment Share on other sites More sharing options...
Julian Posted April 5, 2011 Share Posted April 5, 2011 (edited) Always remember to check for matching double or single flare on the front right brake pipe at the master end. Brilliant advice that I had that problem years ago, it nearly done my head in, made two new pipes before I thought of checking if it was a single or double flare, just assumed it was the same as the master I took off Edited April 5, 2011 by Julian Link to comment Share on other sites More sharing options...
Scribe of Lincoln Posted April 5, 2011 Author Share Posted April 5, 2011 I've got a new cylinder you can have for £40 delivered if that will do the trick Ben? It doesn't come with the reservoir but it is brand new old stock (made by 'Moprod' if I recall correctly.) Send me an e-mail and we'll take it from there if you're interested. All the best, Joe. Hi Joe, E-mail sent. Thanks, Ben Link to comment Share on other sites More sharing options...
Joe Posted April 6, 2011 Share Posted April 6, 2011 Thanks Ben, Photies now on the way to check it's the right one for you. All the best, Joe. Link to comment Share on other sites More sharing options...
