johnboy Posted June 17, 2011 Share Posted June 17, 2011 Looking for a set of standard front springs for a '73 1.9 A series. Reason being i had the wrong springs on when i bought it, i have since fitted a set from a member on here but think they may have been B series lowering springs?? definately lowering springs for something as the coils are so tight one end. Sits well low and looks nice but bangs and crashes everywhere. Have 17x7.5 alloys on so would like to try standard ones to see where i am starting from with regards to suspension height (if that makes any sense) Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted June 17, 2011 Share Posted June 17, 2011 (edited) I believe that you will have to request for stronger ones in GTE HD mode 12.4mm for ex (80 Euros/set) The tires that you have are wide so you will need all the stronger ones and not the normal ones Edited June 17, 2011 by OPEL PARTS GREECE Link to comment Share on other sites More sharing options...
upk Posted June 17, 2011 Share Posted June 17, 2011 have you got front to rear mixed up?? the longer spring should be on the front. kev Link to comment Share on other sites More sharing options...
rayman Posted June 17, 2011 Share Posted June 17, 2011 Will let you know if i still have mine tomo as i just put minus 40s on Link to comment Share on other sites More sharing options...
johnboy Posted June 18, 2011 Author Share Posted June 18, 2011 Cheers Rayman, that would be good. Link to comment Share on other sites More sharing options...
