paul691 Posted June 21, 2011 Share Posted June 21, 2011 (edited) for the few on here that might be running with a rover v8, these are for you. Prices exclude postage, please ask for a quote. I use interparcel.com to keep it cheap. All parts removed from a 3.5 SD1 engine. Front timing case with distributor driven oil pump (gears included) £30 Oil filter housing £10 Oil pick up pipe £10 Distributor drive & spacer £SOLD Distributor clamps £3 each Valley clamp plates £3 Oil filler cap £3 Gear stick (possilbly LT77) £SOLD Water pump (refurb only, very stiff) £5 Crank pulley £SOLD Water pump pulley £SOLD Distributor (housing only, ideal for chroming or powder coating) £5 SU fuel vent pipes £5 Edited July 6, 2011 by paul691 Quote Link to comment Share on other sites More sharing options...
opel2000 Posted June 22, 2011 Share Posted June 22, 2011 Some good stuff there... The front timing case is a good one for anyone that has a Range Rover engine, as the SD1 is a smaller/lower item. Also the short (p5) water pump is now a very sought after item. Quote Link to comment Share on other sites More sharing options...
paul691 Posted July 4, 2011 Author Share Posted July 4, 2011 list updated to show sold items Quote Link to comment Share on other sites More sharing options...
paul691 Posted July 6, 2011 Author Share Posted July 6, 2011 prices updated Quote Link to comment Share on other sites More sharing options...
