mantasrme Posted June 26, 2011 Share Posted June 26, 2011 (edited) Ok i'm having a clearout at my unit of things i'd bought for future projects. Working on other peoples cars full time means i'm not going to get around to using these on my own projects. First a 6 point roll cage with removable diagonal and door bars. Not sure of who manufacturer no stickers on it any more, been used and then stored for a while so paint missing in places Has extra mountings for B pillar, rear feet are single bolts through arch, main hoop 3 bolt, front feet 2 bolt £180 SOLD Next a c20xe to ford bellhousing including clutch arm. Looking at it looks to be a straight rather than 7degrees £120 will post for £10 SOLD Stainless exhaust for a 1800 Manta Hatch 1 3/4" (45mm) diameter with 3 boxes. Not heard this on a running car but should be nice and quiet and never rot out. £55 might be able to post SOLD Big bore stainless exhaust for a GT/e coupe, 2" system with large 3 1/4" (89mm) rolled tail pipe This is loud but also deep, will get you noticed £90 SOLD Collection welcome from Harrogate North Yorkshire, fiting of exhausts or roll cage can be arranged More stuff to follow as i continue clearing out. Will be at billing so can bring things for collection (apart from the cage) Edited July 23, 2011 by mantasrme Quote Link to comment Share on other sites More sharing options...
mantasrme Posted June 26, 2011 Author Share Posted June 26, 2011 Just to add I will be at billing and can bring the exhausts and bellhousing with me. Quote Link to comment Share on other sites More sharing options...
mickappy Posted June 26, 2011 Share Posted June 26, 2011 Al have roll cage mate:-) not sure when i can get over for it but i can pay u at billing. Then collect in a few weeks,If thats ok mick Quote Link to comment Share on other sites More sharing options...
rutts Posted June 26, 2011 Share Posted June 26, 2011 (edited) i can do same with GTE exhaust if ok with you. or fifty with paypal, forty at billing. Edited June 26, 2011 by rutts Quote Link to comment Share on other sites More sharing options...
mantasrme Posted June 26, 2011 Author Share Posted June 26, 2011 Al have roll cage mate:-) not sure when i can get over for it but i can pay u at billing. Then collect in a few weeks,If thats ok mick Mick, Your 2nd in line for the cage, i'll let you know if the first interested party drops out. i can do same with GTE exhaust if ok with you. or fifty with paypal, forty at billing. Andy, Your also 2nd in line. I should have an answer for you tomorrow night. Quote Link to comment Share on other sites More sharing options...
rutts Posted June 26, 2011 Share Posted June 26, 2011 ok no problem. Quote Link to comment Share on other sites More sharing options...
Mantaray80 Posted June 27, 2011 Share Posted June 27, 2011 Is the bellhousing for a Type 9? Is it 4 or 6 cylinder? (Different length shafts) Quote Link to comment Share on other sites More sharing options...
mantasrme Posted June 27, 2011 Author Share Posted June 27, 2011 I was sold it as a type 9 but can check that Depth measured with it flat on floor is 155mm Quote Link to comment Share on other sites More sharing options...
nosmanta Posted July 19, 2011 Share Posted July 19, 2011 I was sold it as a type 9 but can check that Depth measured with it flat on floor is 155mm Hello mate! Still have the bellhousing? Cheers! Quote Link to comment Share on other sites More sharing options...
mantasrme Posted July 19, 2011 Author Share Posted July 19, 2011 Its still here at the moment, but i am waiting on a call from an interested party Quote Link to comment Share on other sites More sharing options...
nosmanta Posted July 22, 2011 Share Posted July 22, 2011 (edited) Its still here at the moment, but i am waiting on a call from an interested party PM sent. But one more thing, this bell is just for RHD right? No hole on the left side. I need it for LHD. I guess I'll have to look for a longer clutch cable..... Edited July 22, 2011 by nosmanta Quote Link to comment Share on other sites More sharing options...
399Road Posted July 23, 2011 Share Posted July 23, 2011 PM sent. But one more thing, this bell is just for RHD right? No hole on the left side. I need it for LHD. I guess I'll have to look for a longer clutch cable..... Nosmanta, If your car has a four branch tubular Manifold fitted , then the Exhaust gets in the way of the clutch cable when you run the box in a left hand drive set up. I've had to get a longer clutch cable made up for my 16V LHD Ascona and use the release arm as it would have been fitted in a RHD car. My new clutch cable now runs all the way around the front of the engine and works perfectly. It was made by a company called "Speedy Cables". I hope this helps you out... Luke. Quote Link to comment Share on other sites More sharing options...
nosmanta Posted July 23, 2011 Share Posted July 23, 2011 Nosmanta, If your car has a four branch tubular Manifold fitted , then the Exhaust gets in the way of the clutch cable when you run the box in a left hand drive set up. I've had to get a longer clutch cable made up for my 16V LHD Ascona and use the release arm as it would have been fitted in a RHD car. My new clutch cable now runs all the way around the front of the engine and works perfectly. It was made by a company called "Speedy Cables". I hope this helps you out... Luke. Hi Luke! Thanks for you feedback. I will be using the cable from the Cossie 4wd that's about 6ft in total length. I hope it will be enough as I tried to get a 6 feet length of wire and tried it on the car. Should be enough. Check out the photo of my engine below: I will be adapting a ZF S5-18/3 classic race box onto the bell. Used this box before with my CIH and was FUNtastic!! Thanks again!! kind regards, Mario Quote Link to comment Share on other sites More sharing options...
