steel Posted August 16, 2011 Author Share Posted August 16, 2011 (edited) fermanta pmd you the tracking number,, i expect youve had the bits by now message box now cleared and hopefully i can get on a bit more often to keep check on things i200 regards freebies ime on the case and they are freebies as a goodwill gesture for the hassle you had with said parts in original deal which ime more than happy to do .............................................................................................................................................................. .............................................................................................................................................................. exclusive recaro front seats very good condition £65 collected rear axle complete [exclusive] hubs rollbar torque tube ect ect low miles £65 rear axle complete [gte] £65 collected gte rear bumper£35 front skirt few hairline cracks but nothing that cant be repaired easily while being prepped for respray in white £30 front crossmember complete £60 collected includes good discs rack top and bottom arms ect manta bonnet with bulge in centre £30 collected.............................binned set of clocks showing 84k miles from an exclusive £40 brand new aluminium solid front crossmember top mounts £50 gte coupe propshaft £20 recaro seat subframes £20 plus post coupe yellow billstein rear shocks £40 plus post exclusive steering wheel £25 dash board top clock cowl rear lights ect ect rover 3.5 ltre sd1 engine factory replacement according to numbers new rocker shafts short nose water pump ect alloy rocker covers £100 no interest ??? need this lot shifted so i can get the coupe in the garage will sell as a job lot offers Edited August 20, 2011 by steel Quote Link to comment Share on other sites More sharing options...
Fermanta Posted August 16, 2011 Share Posted August 16, 2011 fermanta pmd you the tracking number,, i expect youve had the bits by now message box now cleared and hopefully i can get on a bit more often to keep check on things i200 regards freebies ime on the case and they are freebies as a goodwill gesture for the hassle you had with said parts in original deal which ime more than happy to do .............................................................................................................................................................. .............................................................................................................................................................. exclusive recaro front seats very good condition £65 collected rear axle complete [exclusive] hubs rollbar torque tube ect ect low miles £65 rear axle complete [gte] £65 collected gte rear bumper£35 front skirt few hairline cracks but nothing that cant be repaired easily while being prepped for respray in white £30 front crossmember complete £60 collected includes good discs rack top and bottom arms ect manta bonnet with bulge in centre £30 collected set of clocks showing 84k miles from an exclusive £40 brand new aluminium solid front crossmember top mounts £50 gte coupe propshaft £20 recaro seat subframes £20 plus post coupe yellow billstein rear shocks £40 plus post exclusive steering wheel £25 dash board top clock cowl rear lights ect ect rover 3.5 ltre sd1 engine factory replacement according to numbers new rocker shafts short nose water pump ect alloy rocker covers £100 no interest ??? need this lot shifted so i can get the coupe in the garage will sell as a job lot offers Got all my bits from Steel - sound to deal with even if he needs a bit of prompting like myself to get it posted out Thanks again fella Quote Link to comment Share on other sites More sharing options...
steel Posted August 16, 2011 Author Share Posted August 16, 2011 great stuff ,cheers m8 Quote Link to comment Share on other sites More sharing options...
steel Posted August 16, 2011 Author Share Posted August 16, 2011 also have spare top arms lower control arms 2 racks 3 sets of top crossmember to chassis rail mount/bolts anti rollbar front hubs ect ect ect Quote Link to comment Share on other sites More sharing options...
Fermanta Posted August 16, 2011 Share Posted August 16, 2011 (edited) also have spare top arms lower control arms 2 racks 3 sets of top crossmember to chassis rail mount/bolts anti rollbar front hubs ect ect ect If you don't get sorted for 400 wings I might have a pair left but I'm in N Ireland. Won't be able to check to weekend though. They will need work - I had four sets and sold them letting buyers take their pick pretty much of all the stuff I had. I used the third choice set on my own 400R and although they required quite a bit of work they have turned out perfect. In fact I haven't seen as good elsewhere yet although the guy that done mine is top class at body work. I also have a fibreglass four slot panel if it's any good to you - just the bit between the headlights mind & it will need a lot of work. Will get pics sorted at weekend if your'e not sorted by then. Edited August 16, 2011 by Fermanta Quote Link to comment Share on other sites More sharing options...
steel Posted August 16, 2011 Author Share Posted August 16, 2011 (edited) that will be be superb m8 i might know of a 400 bonnet and because its being made into a 1 piece i cant justify using new panels would rather use rougher examples and fibreglass repair and prep as needed Edited August 16, 2011 by steel Quote Link to comment Share on other sites More sharing options...
steel Posted August 17, 2011 Author Share Posted August 17, 2011 (edited) price drop pair front wings good condition £50 no offers ,..if they dont go they shall go in the skip seats.................£50 pair i have the rears which i will throw in for free they havent been cleaned theyre as removed fromanexclusive that was stood for 9 years altho it look like there is there is no rips or tears in the seats its just the pic the drivers side bolster is not as tight as the passenger but thats to be expected but very nice seats Edited August 17, 2011 by steel Quote Link to comment Share on other sites More sharing options...
mantapaperman Posted August 18, 2011 Share Posted August 18, 2011 hi steel. are those wings rusty rot free? and are they postable.. cheers Quote Link to comment Share on other sites More sharing options...
steel Posted August 18, 2011 Author Share Posted August 18, 2011 theres some minor surface rust m8 around mounting lips but nothing thats bad quick blast with a wire brush good as new,, i would post them bud as long as you cover postage no problem Quote Link to comment Share on other sites More sharing options...
steel Posted August 20, 2011 Author Share Posted August 20, 2011 bonnet in bin Quote Link to comment Share on other sites More sharing options...
mantapaperman Posted August 22, 2011 Share Posted August 22, 2011 (edited) i,m really fancying the wings steel, but abit cash strapped at the mo ..are you up for offers? it wont be for a week or two tho..cheers Edited August 22, 2011 by mantapaperman Quote Link to comment Share on other sites More sharing options...
steel Posted August 22, 2011 Author Share Posted August 22, 2011 (edited) sorry buddy ive had a pm from a fella that wants to come collect on wednesday,, if it falls through i will let you know [but its unlikely] Edited August 23, 2011 by steel Quote Link to comment Share on other sites More sharing options...
steel Posted August 24, 2011 Author Share Posted August 24, 2011 wings now sold to julian thanks very much was a pleasure to meet you Quote Link to comment Share on other sites More sharing options...
