ascona i2000 Posted July 21, 2011 Share Posted July 21, 2011 Having a clearout and have alot of CIH engine parts around. All sorts available, from cranks to the smallest obscure bits. Some performance stuff and some standard. 07917665371 Dave Quote Link to comment Share on other sites More sharing options...
cop Posted July 21, 2011 Share Posted July 21, 2011 wots your location dave please , gte fly wheel and clutch , alternator bracket ? Quote Link to comment Share on other sites More sharing options...
adz the stig Posted July 21, 2011 Share Posted July 21, 2011 what performance bits do you have? for a gte Quote Link to comment Share on other sites More sharing options...
mantaboy89 Posted July 21, 2011 Share Posted July 21, 2011 I'm Also interested in any performance bits you may have. Pm me what youve got? Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted July 22, 2011 Share Posted July 22, 2011 any standard size new shells ? Quote Link to comment Share on other sites More sharing options...
ascona i2000 Posted July 22, 2011 Author Share Posted July 22, 2011 wots your location dave please , gte fly wheel and clutch , alternator bracket ? Located in Andover, Hants. Alternator bracket-yes Flywheel-yes Clutch-no! Call or pm if you want either. Dave what performance bits do you have? for a gte Allsorts from solid lifters, oversize valves new an used, twin dcoe inlet manifolds, quite a few cams, (some new), prob easier if you know what you want and ask me. Dave any standard size new shells ? I know i got a pack of new shells, will check size and come back to you. Dave Quote Link to comment Share on other sites More sharing options...
E416 PBO Posted July 23, 2011 Share Posted July 23, 2011 Located in Andover, Hants. Alternator bracket-yes Flywheel-yes Clutch-no! Call or pm if you want either. Dave Allsorts from solid lifters, oversize valves new an used, twin dcoe inlet manifolds, quite a few cams, (some new), prob easier if you know what you want and ask me. Dave I know i got a pack of new shells, will check size and come back to you. Dave What camshafts do you have? Wat manufacturer? What degrees? Quote Link to comment Share on other sites More sharing options...
ascona i2000 Posted July 23, 2011 Author Share Posted July 23, 2011 (edited) What camshafts do you have? Wat manufacturer? What degrees? Hi, off the top of my head OP234, OP254 Enem K3 have a few more bit will have to look. if you go relevant websites you can see full spec on durations and lift etc. I Edited July 23, 2011 by ascona i2000 Quote Link to comment Share on other sites More sharing options...
ascona i2000 Posted July 23, 2011 Author Share Posted July 23, 2011 (edited) I have a started to make a list of the performance stuff as this seems to have the most interest. 4 branch manifold, used £40 Big wing sump cih £30 Irmscher twin dcoe manifolds. Short type £60 2.0 big valve head. req strip and clean £75 2.2 inj rocker cover £40 . 2.4 inj rocker cover £40 8 brand new solid lifters £30 oversize inlet valves, new and used 45+46 £ ? Ally race rocker cover with Wilcox engine plate £60 Ally race rocker cover with Wilcox engine plate riveted on £60 Kent OP234 cam £50 Kent OP 254 £50 Enem K3 £65 2.0 full race head, big valve and gas flowed by DVA power, massive amount of work in this head with matched inlet manifolds for twin dcoe/ throttle bodies. Port and valve work cost £800 alone. Never been used. Required repair before use. Ring or PM for details if interested. Edited July 23, 2011 by ascona i2000 Quote Link to comment Share on other sites More sharing options...
vauxsenb Posted July 28, 2011 Share Posted July 28, 2011 Is the 234 cam new? if yes then can I bag it please cheers, Colin. Quote Link to comment Share on other sites More sharing options...
Brown Job Posted July 29, 2011 Share Posted July 29, 2011 Not interested on performance stuff, I am interested in the bog standard. Anything going? Or are you a performance man only? BJ Quote Link to comment Share on other sites More sharing options...
ascona i2000 Posted July 29, 2011 Author Share Posted July 29, 2011 Is the 234 cam new? if yes then can I bag it please cheers, Colin. Hi, sorry 234 cam has gone. Not interested on performance stuff, I am interested in the bog standard. Anything going? Or are you a performance man only? BJ I have a fair amount of standard stuff. Do you know what you want/need Quote Link to comment Share on other sites More sharing options...
vauxsenb Posted July 29, 2011 Share Posted July 29, 2011 Ok, too latefor the cam, are the solid lifters still available? cheers, Colin. Quote Link to comment Share on other sites More sharing options...
johnboy Posted July 29, 2011 Share Posted July 29, 2011 Is the big valve head, 4 branch and dcoe manifold still available please. Quote Link to comment Share on other sites More sharing options...
Brown Job Posted July 30, 2011 Share Posted July 30, 2011 I have a fair amount of standard stuff. Do you know what you want/need Quote Link to comment Share on other sites More sharing options...
ascona i2000 Posted July 30, 2011 Author Share Posted July 30, 2011 Ok, too latefor the cam, are the solid lifters still available? cheers, Colin. Yep, lifters still available, got 8 brand new and prob 12 second hand. Let me know what you want. Dave Is the big valve head, 4 branch and dcoe manifold still available please. Hi, the head and inlets are still available but 4 branch gone. get in touch if you want th head and inlets. These are genuine Irmscher items. Quote Link to comment Share on other sites More sharing options...
vauxsenb Posted August 1, 2011 Share Posted August 1, 2011 Yep, lifters still available, got 8 brand new and prob 12 second hand. Let me know what you want. Dave Thanks Dave, Can I have the 8 new solid lifters please, and let me know how you want the payment cheers, Colin. Quote Link to comment Share on other sites More sharing options...
ascona i2000 Posted August 2, 2011 Author Share Posted August 2, 2011 Thanks Dave, Can I have the 8 new solid lifters please, and let me know how you want the payment cheers, Colin. Colin, if you PM me yout address i will post them to you. Cheque in post would be fine. Dave Quote Link to comment Share on other sites More sharing options...
nickincrete Posted August 20, 2011 Share Posted August 20, 2011 Any new cam bearings for 2.4 Quote Link to comment Share on other sites More sharing options...
611 Posted August 20, 2011 Share Posted August 20, 2011 Hi Dave Im after a GTE front timing chain cover, i dont suppose you have one of those? Andy Quote Link to comment Share on other sites More sharing options...
Thomas77GR Posted August 27, 2011 Share Posted August 27, 2011 hello do you have a good brake servo that would suit my A series? i'll have the used 4branch manifold (does it come with the downpipe?) thanks Thomas Quote Link to comment Share on other sites More sharing options...
