manta3000 Posted August 22, 2011 Share Posted August 22, 2011 hi anyone know where to get inner sills manta gte? cheers colin Link to comment Share on other sites More sharing options...
steel Posted August 22, 2011 Share Posted August 22, 2011 (edited) dont think you can get inner cills ime probably wrong but i remember years ago before i got tinternet i couldnt get them ,,ended up folding my own and them being more square but did the job fine Edited August 22, 2011 by steel Link to comment Share on other sites More sharing options...
opel2000 Posted August 23, 2011 Share Posted August 23, 2011 I think that the inner sill is actually the floorpan. Floorpan profile curves up and goes vertical before having a rolled edge to the flange that the outer sill spot welds to (door seal sits on this) then the sill curves down and out to meet the door shut line, before curving under (side skirt area) then going horizontal with a flange/lip to weld to floorpan. It is the curves on the pressing of this profile that gives the sill and the shell a lot of strength in this area when tied into the shell correctly. Link to comment Share on other sites More sharing options...
keith1200 Posted August 23, 2011 Share Posted August 23, 2011 (edited) Clive is 'spot on' you need these: Check the members section under (supplier links) Edited August 23, 2011 by keith1200 Link to comment Share on other sites More sharing options...
manta3000 Posted August 23, 2011 Author Share Posted August 23, 2011 hi is this the floor pan as sold by ps autoteile-de,if so im away to purchase 2 anyway,along with lower 3/4 rear repair panels,dont think anyone else does these? needing outer sills as well,so should all come together, still slightly confused on explanation of inner sill,but should become more clear when apart i hope cheers colin Link to comment Share on other sites More sharing options...
steel Posted August 23, 2011 Share Posted August 23, 2011 think theres a drawing of inner cill/floor in montza,s a series project thread may help you understand Link to comment Share on other sites More sharing options...
