chewy Posted August 31, 2011 Share Posted August 31, 2011 hello all, right i am feed up i have a 1.9 manta a and would love to convert it to a bosch distributor at the mo its a delco remy and there is no eletronic convertion kit for it. looking at others out there the engine is the same its all the same just mines got a silly french distributor on it.... please help Link to comment Share on other sites More sharing options...
ray70 Posted September 1, 2011 Share Posted September 1, 2011 Hi there, I done the exact same thing with mine, but I was lucky and was given a bosch dizzy free. I bought one of those electronic conversion kits of ebay. you could always try german ebay they tend to have more bits but can cost a bit more too also I think that I saw an ac delco conversion kit on the American ebay when I was serching for one for mine (ebay.com) Good luck Ray. Link to comment Share on other sites More sharing options...
lamchop77 Posted September 1, 2011 Share Posted September 1, 2011 hello all, right i am feed up i have a 1.9 manta a and would love to convert it to a bosch distributor at the mo its a delco remy and there is no eletronic convertion kit for it. looking at others out there the engine is the same its all the same just mines got a silly french distributor on it.... please help Have you tried H & H ignition solutions, they will prob be able to sort you something. Chris Link to comment Share on other sites More sharing options...
cam.in.head Posted September 1, 2011 Share Posted September 1, 2011 the IDEALdistributor for this will be a bosch electronic one from a 1982-1986 vauxhall carlton 2 litre carburretted car.the 1.9 & 2 littre one listed the same distributor advance curves etc. these will be very hard to source now.maybee german ebay. the next best bet & one which will be more or less correct will be from a 2 littre manta gte. the settings were slightly different on carb & injection cars but should work ok. other members will have done this & could possibly comment on this. in either case you will need the matching coil,control box & mini wiring loom. Link to comment Share on other sites More sharing options...
