mantaboy89 Posted September 7, 2011 Share Posted September 7, 2011 Anyone got a wiring diagram for the injection loom on a gte, if someone could post one or a link it would be much appreciated. Quote Link to comment Share on other sites More sharing options...
monzta Posted September 8, 2011 Share Posted September 8, 2011 I dont have any but i can tell you straight away that it is incredibly simple to install in a carburettored car. When everything is connected you should have 3 or 4 wires left in a small square connector. The wires here are colour coded and are brown, green and blue. The last wire is most often black/red although i can´t really remember. If it is black/red it should be connected to your startere engine. Green is for ign, brown for ground - and blue is signal to your fuel pump. On newer engines one or more of theese wires can be white instead. If they are they have numbers written on them, and you will then be able to find out where they go when checking a wire diagram. But as said, everything is simple on a Manta Quote Link to comment Share on other sites More sharing options...
mantaray Posted September 8, 2011 Share Posted September 8, 2011 If you let me have your email address, I can email you a PDF wiring diagram. Quote Link to comment Share on other sites More sharing options...
mantaboy89 Posted September 13, 2011 Author Share Posted September 13, 2011 Cheers dude my email is tubbyviva@yahoo.co.uk thanks Quote Link to comment Share on other sites More sharing options...
