Retro Power Posted September 12, 2011 Share Posted September 12, 2011 We are now starting to supply Bilstein shock absorbers at good prices. The first kit I've sorted is the 'B8' kit. These are very high spec, shortened bodies, for cars running 30-60mm lower than standard. Ideal for track cars, lowered fast road, or fast tarmac rally. The damping and rebound rates are 330/120 at the front and 220/80 at the back. These work well with 400-500lb springs up front and 200-250lb at the rear. The full set is £450 including post to UK. £460 if southern Ireland. payment by Paypal or bank transfer - email/PM for details. I'll be putting together packages for Manta A, Kadett/Chevette etc as well as standard ride height Manta B over the next few weeks, so pls ask if there is something you are after. Quote Link to comment Share on other sites More sharing options...
opelmantagsi Posted September 12, 2011 Share Posted September 12, 2011 I could be interested in a set for a GTE hatch with 25mm lowered (reset) standard springs, hard as nails would be good. Quote Link to comment Share on other sites More sharing options...
Retro Power Posted September 13, 2011 Author Share Posted September 13, 2011 I could be interested in a set for a GTE hatch with 25mm lowered (reset) standard springs, hard as nails would be good. If you like a firm ride, then the above kit would be fine. If you would prefer it a bit more compliant, then the B6 kit would be better - I'm just clarifying the damping rates, as there is a bit of confusion at Bilstein over the availability of the various rates available. Callum. Quote Link to comment Share on other sites More sharing options...
E416 PBO Posted September 13, 2011 Share Posted September 13, 2011 If you like a firm ride, then the above kit would be fine. If you would prefer it a bit more compliant, then the B6 kit would be better - I'm just clarifying the damping rates, as there is a bit of confusion at Bilstein over the availability of the various rates available. Callum. Looking forward to seeing how you get on with these kits. I'll be definately interested. Are you organising springs too? Luke. Quote Link to comment Share on other sites More sharing options...
Zap Posted October 12, 2015 Share Posted October 12, 2015 Do you still have Bilstein B8 for sale? I have an Opel Ascona B with 55mm H&R lowered springs. Zap 1 Quote Link to comment Share on other sites More sharing options...
