marius Posted October 5, 2011 Share Posted October 5, 2011 Is there enough space to fit X25XE engine+ gearbox into manta a? Woud manta b 2.0s rear axle be a perfect match for this configuration? Quote Link to comment Share on other sites More sharing options...
monzta Posted October 5, 2011 Share Posted October 5, 2011 Don´t really know about the first part but i think that if you can shoehorn in a V8 from a Rover a V6 should be possible too unless its too wide! ? Regarding the rear axle i would go for a stronger rear axle. The A and B series rear axles are identical except for the width wich is a bit more on the B series car (about 25mm per side). I would recommend a DANA rear axle from a Volvo 240 series car. They are unbreakable and are known to be able to handle 500nm´s and more. The width is between the A and B series and even though there´s some work to make it go in you will never ever regret this mod Quote Link to comment Share on other sites More sharing options...
opel2000 Posted October 5, 2011 Share Posted October 5, 2011 With no bulkhead modification you will find that you'll need to cut the bonnet to clear the timing covers of the engine, or you can cut the crossmember and lower the engine but you will also have to alter the steering rack height which will lead to steering/bump steer issues. Best bet would be to look into altering bulkhead area to site the lump a bit further back, but then as with everything like this you could end up with no heater or awkward heater installation which makes a car that has had a lot of time, effort and cash put into it not that nice to drive as soon as a bit of heat is needed to demist the screen for example. Quote Link to comment Share on other sites More sharing options...
mantaray Posted October 5, 2011 Share Posted October 5, 2011 Yes it will go in, but it's not a straght swop. I modified the front cross member to get the engine low, as I did not wish to cut the bonnet. But as Clive has said this will cause steering/bump steer issues which i got round like this. You will also need to make a custom sump and exhaurst system. As I said above it is not straght folward but not too hard ether if you are good with your hands BUT if you do fit one I garrentee you will have a smile on your face. 1 Quote Link to comment Share on other sites More sharing options...
monzta Posted October 5, 2011 Share Posted October 5, 2011 There´s a guy from Finland (they are quite mad those "Fins") that have a Buick GN Biturbo V6 engine in his A series.. Quote Link to comment Share on other sites More sharing options...
Shug Posted October 6, 2011 Share Posted October 6, 2011 There´s a guy from Finland (they are quite mad those "Fins") that have a Buick GN Biturbo V6 engine in his A series.. I thought all the nordics were a bit nuts... Quote Link to comment Share on other sites More sharing options...
monzta Posted October 6, 2011 Share Posted October 6, 2011 We are indeed We dont get out much you know Quote Link to comment Share on other sites More sharing options...
marius Posted October 10, 2011 Author Share Posted October 10, 2011 Where can I find some info about those volvo LSD's? Google says that there are 2 types Dana 30 and Dana 31 ,which one is the best chose? Can I alter the oil pan of this V6 engine and lower the engine in this way ? Quote Link to comment Share on other sites More sharing options...
monzta Posted October 11, 2011 Share Posted October 11, 2011 Where can I find some info about those volvo LSD's? Google says that there are 2 types Dana 30 and Dana 31 ,which one is the best chose? Can I alter the oil pan of this V6 engine and lower the engine in this way ? The DANA 31 is the strongest of the 2 types. The ring and pinion gear is just a little bigger than the 30 rear axle´s and it makes a big difference. The Dana 31 is found on Volvo 700 series cars, mostly on turbo and 6cyl versions. If you want a original Volvo LSD rear axle it is called a Dana 41 and uses a eaton LSD. However theese will propably be worn down from years of use and cost some heavy £. My suggestion is to find a good and neat Dana 31 and buy a TruTrack LSD from the US (about 250£ + freight). The thing is that the Dana rear axle really is from the US to begin with. It´s a heavy duty axle that has been used alot by Jeep. So a LSD for a rockcrawling jeep will be a direct swap if of couse the Jeep run a Dana axle. You will end up with a near unbreakable rear axle. Quote Link to comment Share on other sites More sharing options...
cop Posted October 12, 2011 Share Posted October 12, 2011 (edited) Hope this helps omega 2.5 engine bolted to a 1800 manta gearbox chap with a cav 2.5 steel sump The engine view view of the gearbox ,you dont have to cut out the bulk head , i did, due to the ehaust manmanifolds and down pipe Complte view with the tunnel removed . IF your intersted i still have the steel sump and oil pick up pipe, plus a new gasket . cheers steve Edited October 12, 2011 by cop Quote Link to comment Share on other sites More sharing options...
madmantamik Posted October 12, 2011 Share Posted October 12, 2011 just to complicate things a little further the jeep cherokee XJ uses a dana 30 in the front and a dana 35 in the rear . no standard jeeps use a lsd in the front but some had them fitted as an optional extra in the rear, and to make it even more complicated some rear diffs are 27 spline and some are 31 spline. there are aftermarket locker diffs to fit the dana 30 but i would not really recommend these for 100% road use. Quote Link to comment Share on other sites More sharing options...
Retro Power Posted October 12, 2011 Share Posted October 12, 2011 ..................and to complicate even more, the salisbury 4ha axle that we put into mantas and kadetts etc is basically a Dana 44, even bigger and stronger again! The dana 44 lsd units fir straight in, and are pretty common in jaguar xj40's in the uk, certainly much more so than volvo lsd units. Quote Link to comment Share on other sites More sharing options...
marius Posted February 13, 2012 Author Share Posted February 13, 2012 will r25 or r26 omega b 3.0 gearbox be a perfect match for c20xe? Quote Link to comment Share on other sites More sharing options...
mantaray Posted February 14, 2012 Share Posted February 14, 2012 Bell housing blot patten is the same, what the gearing will be like I don't know. Quote Link to comment Share on other sites More sharing options...
marius Posted February 14, 2012 Author Share Posted February 14, 2012 (edited) thanks just bought x25xe , but I don't have the imobiliser and transponder(ignition key).Is there any any solution to this problem? I read somewere that it is posible to bypass the imobiliser on certain types of ecu by rewriting eeprom.Does anyone did this? Edited February 15, 2012 by marius Quote Link to comment Share on other sites More sharing options...
marius Posted February 21, 2012 Author Share Posted February 21, 2012 where can I find some info about omega gearboxes? I don't know what to chose ? Have an offer for R25/26? Will this be ok for an V6 2.5? Quote Link to comment Share on other sites More sharing options...
