Posted (edited)
This is a 34mm DATC weber carb with K+N filter and adaptor plate to fit to the manta carb inlet manifold.
It has an automatic choke setup but that could be converted to a manual if you wanted
Came from a 1.8ohc engine with a kent cam fitted so it may require re-jetting for your engine
The adaptor plate will also fit the Cih carb manifold
I'm after £50 £30 plus £10 postage to mainland UK
Or collect from Harrogate N,Yorks
Edited by mantasrme
  • 4 weeks later...
  • 5 months later...
