i2000 Posted November 16, 2011 Share Posted November 16, 2011 wanted as above to fit a 1985 2.0 gte as mine is badly corroded in the water ways,part numbers are 90090599 36-1305632 f1,in the wolverhampton area or post,thanks. Link to comment Share on other sites More sharing options...
611 Posted November 19, 2011 Share Posted November 19, 2011 Hi, are you running injection or carbs? as i have one that dosnt have the timing pickup on so only any good if your running carbs. i might have one with the pickup but will need to have a rummage about in the garage. i should get chance on tuesday if thats any good. Andy Link to comment Share on other sites More sharing options...
i2000 Posted November 19, 2011 Author Share Posted November 19, 2011 Hi, are you running injection or carbs? as i have one that dosnt have the timing pickup on so only any good if your running carbs. i might have one with the pickup but will need to have a rummage about in the garage. i should get chance on tuesday if thats any good. Andy Hi, are you running injection or carbs? as i have one that dosnt have the timing pickup on so only any good if your running carbs. i might have one with the pickup but will need to have a rummage about in the garage. i should get chance on tuesday if thats any good. Andy hi thanks for the reply it is injection. Link to comment Share on other sites More sharing options...
611 Posted November 23, 2011 Share Posted November 23, 2011 had a rummage around in the garage today but could only find one thats good for a carb setup so will venture into the loft tomorrow! and see what i can find. If i can find anything and make my way back out i will let you know and post a picture as im sure there is one about somewhere! Andy Link to comment Share on other sites More sharing options...
611 Posted November 23, 2011 Share Posted November 23, 2011 Hi, made it out of the loft and have this one. The number on the side matches up with yours. It needs a good clean up but water ways are fine and so is the oil pump gear housing. How does £40 + postage sound? (which should be about £6) i should also have a spare front seal you can have if you need one? Andy Link to comment Share on other sites More sharing options...
lamchop77 Posted November 23, 2011 Share Posted November 23, 2011 i2000 Timing pickup doesnt matter on a std GTE motor, mine hasn't got one on and mines an 86!!! Maybe its an older one but it ran fine. Both race motors have run without tem as well Chris Link to comment Share on other sites More sharing options...
611 Posted November 23, 2011 Share Posted November 23, 2011 Hey Chris Thanks for the info, i have and A series so didnt know much about how the injection was setup on the GTE and had two covers one with a pickup on it and one without and thought it must have been the one with the pickup that was needed on a GTE. i2000, i can have a look at the one without the pickup and see what the number on it is and check its condition, i think its all good but can check tomorrow. Andy Link to comment Share on other sites More sharing options...
