Kevin Abbott Posted January 30, 2012 Share Posted January 30, 2012 (edited) Got this a few years ago, was told it is the full set up to lose the dizzy and go distributorless, however as I have never fitted to a car I can't confirm that ECU not included as it is from a GSI Cav CAT car Edited February 15, 2012 by Kevin Abbott Quote Link to comment Share on other sites More sharing options...
Retro Power Posted February 2, 2012 Share Posted February 2, 2012 Hi Kev, is the ignition amp hiding in the loom? If not then its missing that but looks complete otherwise. If you have the amp I'll have a haggle Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted February 4, 2012 Author Share Posted February 4, 2012 Hi Nat/Cal I'm not sure about the ignition amp, the setup I got from a guy who got it from a bloke on migweb who said it was a full setup. I have been Pm'd prior to your post about this but if it falls through I'll give you a bell Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted February 5, 2012 Author Share Posted February 5, 2012 Sorry but I have checked the ECU that is with this set up and it doesn't run a dizz pack set up For sale is the loom, dizz pack, cam sensor etc but I do not have a ECU to suit this You need to add a motronic 2.5 or 2.8 with a number PT on the ECU case Price changed to £50 Quote Link to comment Share on other sites More sharing options...
nosmanta Posted February 12, 2012 Share Posted February 12, 2012 Sorry but I have checked the ECU that is with this set up and it doesn't run a dizz pack set up For sale is the loom, dizz pack, cam sensor etc but I do not have a ECU to suit this You need to add a motronic 2.5 or 2.8 with a number PT on the ECU case Price changed to £50 Hey Kev! I've got a 2.8 ECU for that which I no longer use as I went standalone. I can post it to you but the only problem is, it here in the Philippines. Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted February 12, 2012 Author Share Posted February 12, 2012 Hi. Thanks for the offer. It has already been sold without the ecu so I dont need one. Cheers Kev Quote Link to comment Share on other sites More sharing options...
