autoworks Posted April 29, 2012 Share Posted April 29, 2012 looking for a manta axel please guys this is for a budget build so cheap as possible hasnt got to be anything special just cope with a bit more power than a standard chevette one will i am in oswestry shropshire but dont mind traveling for the right part thanks phill 07538354250 Link to comment Share on other sites More sharing options...
johno Posted April 29, 2012 Share Posted April 29, 2012 Hi phill, i have axle off manta gte laying around, but i chopped off metal work that holds springs and shocks to axle,prior to that the axle seemed good one with no wines..regards neil. Link to comment Share on other sites More sharing options...
bones Posted April 29, 2012 Share Posted April 29, 2012 HS axle and Manta A axle on ebay at the moment. Link to comment Share on other sites More sharing options...
casper1483 Posted April 29, 2012 Share Posted April 29, 2012 I've got one off a 1.9 if you fetch it you can have it, will need new brake components as I've robbed it of those, cheers Link to comment Share on other sites More sharing options...
autoworks Posted April 29, 2012 Author Share Posted April 29, 2012 whats your postcode casper?? pm me if you like or send a text bones there both mega money on ebay and the one is a disc setup cheers anyway johno were are you and how much you after??? Link to comment Share on other sites More sharing options...
opelmantagsi Posted April 30, 2012 Share Posted April 30, 2012 one out of a 1.8 Manta might be the best option, different diff ratio than the 2.0 Link to comment Share on other sites More sharing options...
mantaray Posted April 30, 2012 Share Posted April 30, 2012 If it's to go into a chevette, then you need an A series axle. One from the later GTEs ect are 1" wider and your wheels may not fit. Link to comment Share on other sites More sharing options...
opelmantagsi Posted April 30, 2012 Share Posted April 30, 2012 (edited) I was lead to believe the Manta B / C one is very similar to the one fitted in the HSR Chevette or is used by guys doing a replica HSR Chevette yes its 25mm wider / longer overall so pushes wheels out 12.5mm each side Edited April 30, 2012 by opelmantagsi Link to comment Share on other sites More sharing options...
bones Posted April 30, 2012 Share Posted April 30, 2012 There are 3 different widths for these type axles, HS, Manta A and Manta B. I can measure a HS and Manta A axle for you tomorrow, there should be someone on the forum able to tell you Manta B length. I'll measure from backing plate to backing plate and let you know. Link to comment Share on other sites More sharing options...
opelmantagsi Posted April 30, 2012 Share Posted April 30, 2012 I have measured the standard chevette and manta gte axle and I came up with 25mm was thinking of using the manta axle myself in my sons chevette but thats a future project Link to comment Share on other sites More sharing options...
johno Posted May 1, 2012 Share Posted May 1, 2012 give me 20 sqid can take it away.. im nottingham junction 26 m1. Link to comment Share on other sites More sharing options...
bones Posted May 1, 2012 Share Posted May 1, 2012 Chevette HS axle length 1240mm (backing plate to backing plate) Manta A axle length 1260mm Manta B ? (longer than a Manta A axle) Link to comment Share on other sites More sharing options...
Robbie Posted May 1, 2012 Share Posted May 1, 2012 manta B is 2" longer than the A Link to comment Share on other sites More sharing options...
simon p Posted May 2, 2012 Share Posted May 2, 2012 I have one, just removed from an A Series £300 Link to comment Share on other sites More sharing options...
kurt Posted June 4, 2012 Share Posted June 4, 2012 hi i,v got manta b/c just taken off gte all complete only in chester Link to comment Share on other sites More sharing options...
