davo Posted May 27, 2012 Share Posted May 27, 2012 is the ecotec version of the16v the same engine as the redtops found in cavs & astras if not what are the differences? does it give the same power /is it just more fuel efficent? thanks in advance Quote Link to comment Share on other sites More sharing options...
blitzi Posted May 27, 2012 Share Posted May 27, 2012 its 150 bhp in the ecotec but you cany tune them like the redtop i have one in manta and think its sufficent!! Quote Link to comment Share on other sites More sharing options...
mantasrme Posted May 27, 2012 Share Posted May 27, 2012 I thought the ecotec was less than the XE's 150 The ecotec has a different manifold and injection wiring loom etc, also the late Ecotecs had a built in immobiliser so you need the ignition key/receiver aswell as the loom Quote Link to comment Share on other sites More sharing options...
blitzi Posted May 27, 2012 Share Posted May 27, 2012 well i think its 147bhp but its more than ample for manta mines is from a 1995 cavalier so no need for ignition sys also running standard injection its also a lot cheaper to purchase than the redtop ie less than half the price!! Quote Link to comment Share on other sites More sharing options...
spiney_norman Posted May 27, 2012 Share Posted May 27, 2012 Ecotecs are 136bhp IIRC. Quote Link to comment Share on other sites More sharing options...
mantadoc Posted May 27, 2012 Share Posted May 27, 2012 Ecotecs are 136bhp IIRC. True (But I bet most Redtops have lost more that 14 BHP in the last 24 years) Quote Link to comment Share on other sites More sharing options...
monzta Posted May 29, 2012 Share Posted May 29, 2012 If you scrap the electronics and go double carb instead you will get the same powergains from a Ecotech as a XE, but you will have a 10-15+ year newer engine Quote Link to comment Share on other sites More sharing options...
