New Old Stock Parts Updated And Some Cheaper
alymac
all new old stock, and manta b unless stated , can be collected at billing if pre paid, can take pay pal only as gift please
alyma2610@tiscali.co.uk
throtle cable 1.6 1.9 2.0 auto £20 each 90076349 x 4 got two different lengths off these
ing lock housing £20 9288641
bonnet adjuster only one single left £3 posted
fog light switches rear £8 each 9283317 x 4
fog light switch front £9 9283316
rear screen washer jet- hatch £10 90087619
circut board dash, with rev counter £20 9285650
rear wiper arm cover hatch (below arm) £3 each 90045769 x2
rear side glass fixed glass seal £35 9007822 hatch rhs side glass fixed type
washer pump £12 3465596 (came unpackaged many be dusty) (also for a series)
rear fog lamp £15 9283830
ring gear £40 cih 8930049
crank pulley 1.8s £10 each 90106896 x2
Edited by alymac
ascona b rear light lens £30 9283236
ascona b front bumper fitting kits chrome £22 each 90020326 x2
ascona b ind lens £3 90019025
ascona b spring for bonnet lock £3 each 90055299 x 8
CIH seal for head timing cover £4 for 10
front j shaped trim clips (expandable - hole required) £7 for 15 (also for a series)
cih gaskets distributors £1 for 5 8930204
lamp holder £3 9283245
front door seal along door top £25 9282912 rhs
wiper arm £10 90087742
hatch parcel shelf ropes £5 each x 3 90078494
contact points £4 each 8983490 x5 (also got new points screws £1 for 3 )
Can I have a pair of the bonnet adjuster rubbers please?
Also, are the diff bearings for a 2.0 manta axle or the baby axle?
Thanks, Scott.
bearings are 1.6 1.9 2.0
also have one pinion bearing small one only
and carrier bearings for 400 diff possible pinion for 400
Edited by alymac
Cool, Ill have the diff bearings for a 2.0 aswell.
can you PM me the final amount including postage and an address for paypal please?
Cheers,
Scott.
pm sent
side glass coupe £30 90103708 bronze opening (got x3 new fixed clears £20)
headrest x2 black £50 90073522
sump gasket £6 cih 8983127
ascona b rear panel £200
manta b wing £250
ascona b side panel 2 door £300
Edited by alymac
I was asking about the door seal but if its ok with you let Sutty 2006 have it, he has asked about it above, I have two here that are ok but I still want the outrigger washers and other bits we e-mailed about
Derek
If you asked about it first then you have first choice.. its up to you. They are hard to find and ive been after both sides since i bought my first manta 6 years ago :D
  • 1 month later...
