ascona i2000 Posted July 3, 2012 Share Posted July 3, 2012 For sale. Very high spec 2.0 steel race/rally engine. Will list from sump upwards... Baffled sump, Farndon billet steel crankshaft, Farndon I beam steel conrods Wossner forged high comp pistons, Big valve head, (DVA power milton keynes) 45mm inlet, 41mm ex Vernier timing gear, Port matched twin carb manifold Enem R12 camshaft, 316degree 12.5mm lift VERY VERY RARE shaft mounted roller rockers. (Hens teeth)!! Opel GT motorsport rocker cover Twin Weber 48 DCO SP Carburettors, Distributor with lumenition electronic ignition kit, The engine was rebuilt over the winter just gone and only done 2 meetings since, Power figures in february after rebuild showed 199bhp and 156lb torque. The engine revs safely to 8000RPM no problem. Would also come with spare full race cylinder head (john noble worked) Price £5500. 07917665371 MOB Quote Link to comment Share on other sites More sharing options...
