Kevin Abbott Posted August 2, 2012 Share Posted August 2, 2012 Hi, I've a bolt in cage in my project. If I add extensions to it, ie, harness tube. Do I need to do it in CDS? Can I just use normal tube with the same diameter and wall thickness? Ta Kev Quote Link to comment Share on other sites More sharing options...
mantasrme Posted August 2, 2012 Share Posted August 2, 2012 If you're not planning to do any form of motorsport then in theory you can use any tube you want. But for what its worth i'd use CDS every time, they spec it in rally cars for a reason and if the worst was to happen it might make the difference Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted August 3, 2012 Share Posted August 3, 2012 Yep defo use CDS any other tube can split down the seam in an impact. Whatever the outside dia use a wall thickness of 2.5mm minimum. Cheers Chris Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted September 11, 2012 Author Share Posted September 11, 2012 Sorry Chaps, forgot to thank you for the advise CDS it is then Quote Link to comment Share on other sites More sharing options...
