Gedly Posted August 11, 2012 Share Posted August 11, 2012 Hi does anyone know the correct setting for my gte It's an 86 not unleaded 2l CIH Thanks. Quote Link to comment Share on other sites More sharing options...
manta400john Posted August 11, 2012 Share Posted August 11, 2012 I'd hazard a guess at 7 degrees, but don't have info to hand. Retarded 3 degrees from standard rings a bell. John. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted August 11, 2012 Share Posted August 11, 2012 an 86 will be unleaded unless its had an earlier head fitted.yours should have P2E stamped on the side to be sure.The standard timing marks on the pulley & timing case relate to using 4 star.(97 octane)set it to this as a basic setting & then you are supposed to retard it by 5 degrees if using 95 octane unleaded but some experimenting is necesarry depending on the condition of the engine & the type of unleaded you are using.if you use super unleaded,the high octane stuff then you should be ok on the 4 star settings. Quote Link to comment Share on other sites More sharing options...
Gedly Posted August 11, 2012 Author Share Posted August 11, 2012 Hi thanks for getting back to me. The head says XR2E which I have been told means it's not unleaded ready. So what should I set the timing to? Thanks. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted August 13, 2012 Share Posted August 13, 2012 i would set it to the factory marks & then retard it a further 5 degrees. it realy is a case of experimentation to get the best setting .i have set mine & then backed it off a little at a time until no pinking is evident. 1 Quote Link to comment Share on other sites More sharing options...
