paul1393 Posted August 14, 2012 Share Posted August 14, 2012 (edited) I have for sale a Commodore B GS/E brake master cylinder in perfect working order. This master cylinder is a direct fit to a Manta ATE servo and will make an excellent up-grade especially if you have changed your rear drums for discs and callipers. The reservoir attached came from a late Vauxhall Carlton. The GS/E Commodore was an all disc set-up. The master cylinder bore is 23mm. I had this master cylinder completely reconditioned and re-sleeved with a stainless steel sleeve a few years ago by "Past Parts" of Bury St Edmunds. As I have now changed my Servo for a more powerful after market one http://www.summitrac...SUM-760122-BLK/ In case any of you are interested in this mod, the servo is the same diameter as a manta servo, however as it is double diaphragm it gives twice as much assistance. The Commodore master cylinder won't fit. I am now using a Wilwood master cylinder http://www.jegs.com/...8555-P/10002/-1. Price for the Commodore M/Cylinder £50 plus £6.50 p&p. Edited August 16, 2012 by paul1393 Quote Link to comment Share on other sites More sharing options...
casper1483 Posted August 14, 2012 Share Posted August 14, 2012 DOH ! . Just bought one off Fliebay £75 cos mine has shat itself......... It's new though but I'd have much rather paid £50 :-( Quote Link to comment Share on other sites More sharing options...
paul1393 Posted August 30, 2012 Author Share Posted August 30, 2012 Now sold! Quote Link to comment Share on other sites More sharing options...
