paul1393 Posted September 11, 2012 Share Posted September 11, 2012 (edited) This panel has never been repaired in the past there is no filler or bodging anywhere. However it now needs repairs to the following two areas before fitting. 1) The area outboard of the offside headlamp aperture. Single skin and accessable area should be an easy repair before fitting. 2) Area on the inside of the lower front panel. I have removed the paint form the damaged area so the extant of the damage on both sides can be viewed. The photo below shows the small area where the rust on the inside of the lower panel has perforated to the other side. Very accessible on both sides for repair. Price £250 I can arrange courier services for £70. Mainland UK. Edited September 11, 2012 by paul1393 Quote Link to comment Share on other sites More sharing options...
sreedman Posted September 14, 2012 Share Posted September 14, 2012 Hi there, Interested in your manta a front end. Where abouts are you? Wouldn't mind coming to have a look at it if u not 2 far away. Thanks Sarah and Steve Quote Link to comment Share on other sites More sharing options...
paul1393 Posted September 18, 2012 Author Share Posted September 18, 2012 Hi there, Interested in your manta a front end. Where abouts are you? Wouldn't mind coming to have a look at it if u not 2 far away. Thanks Sarah and Steve Hi, Sorry the front panel is now sold. Paul. Quote Link to comment Share on other sites More sharing options...
