Beaker Posted October 25, 2012 Posted October 25, 2012 2 of these 9" Friction Disks to clear out, additional info and pictures here The clutch units measure a shade over 9 inches in diameter, research has revealed that the 9 inch unit is used behind the 2.2L engine on the Opel Rekord 2.2L EFIs. It is possible that this unit is also compatible with the 2.4L engine used in the early 5 door Vauxhall Frontera AWD S.U.V. I double checked the mounting spline for compatibility with the humble 4 speed GM gearbox fitted to the Opel Manta A series and many other classic Opels. However, it should be noted that this size of clutch plate is too wide for the flywheel on a standard 2 litre C.I.H. engine. Quote
rutts Posted October 27, 2012 Posted October 27, 2012 after you buy the clutch off beaker talk to drew he has a few flywheels off monzas Quote
Beaker Posted October 27, 2012 Author Posted October 27, 2012 A number of people have asked about cost, sorry I should have mentioned £15 plus postage. I'll double check, but I estimate £7.50 to the UK. Quote
doveyte2800 Posted November 25, 2012 Posted November 25, 2012 Hi, Have you still got a clutch plate for sale? If so can you count the number of splines on it please, just to be safe. Regards Ian Quote
Beaker Posted November 25, 2012 Author Posted November 25, 2012 I count 14 splines, hope this works for you. Quote
Beaker Posted December 9, 2012 Author Posted December 9, 2012 Last bump for 2012, 2 units sold, last one to go. Plus any feedback? Quote
