Mk1 Cavalier Sports Hatch / Manta? Brake Servo
andy88890
Ok, just had a call from the garage and my brake servo is rusted out (this would explain me having to put all 15 stone on the brakes just to stop it! Does anyone have a good second hand one that will fit? Or know if a manta one will fit? Or indeed any other one fit? If so drop me a message!
still after a servo and a master cylinder... anyone got these spare?
Beware when changing master cylinder as one of the brake pipes might need changing, front right if I remember correctly, because some cylinders need single flare and some need double flare on one of the pipe and no one will look for that unless they know.
I thin it is someting daft like master cylinder end of front right brake pipe (the one only a few inch long) is double flare on later cylinders and single flare on early, I think it is thid because if it was other way around I would have used tool to make the single flare a double instead of changing. Obviously depends what was fitted, Just saying check carefully (prefferably check all)
Note:
I got a new one from brakes international but it took 2 months to come and paint was still tacky when I got it. Was £176 at the time.
There are some references aroung to people using golf servo / master cylinder is you search hard enough
