opelmantagsi Posted November 13, 2012 Share Posted November 13, 2012 anyone have or know where to find these? Link to comment Share on other sites More sharing options...
andyc Posted November 13, 2012 Share Posted November 13, 2012 Hi Derek What fuse box are you using? The Terminals for the Cavalier/Calibra box i'm using are You just break them off the strip as you want You could try these guys as they have alot of different OE connectors www.simtekuk.co.uk Cheers Andy Link to comment Share on other sites More sharing options...
opelmantagsi Posted November 13, 2012 Author Share Posted November 13, 2012 they are from a Ford Mondeo fuse / relay box from what I can gather they are called JPT Recepticals (junior power timer) http://www.te.com/catalog/feat/en/c/11557 the two bigger ones dont have barbs on the sides as the barbs are in the relay housings. I will e-mail simteck today and see what they have, cheers for this Derek Link to comment Share on other sites More sharing options...
opelmantagsi Posted November 26, 2012 Author Share Posted November 26, 2012 ok I am beaten on the Ford option so will need to change my thinking Anyone have these GM ones? Link to comment Share on other sites More sharing options...
andyc Posted November 26, 2012 Share Posted November 26, 2012 Hi Derek That larger one, is that for a maxi fuse? Cheers Andy Link to comment Share on other sites More sharing options...
opelmantagsi Posted November 26, 2012 Author Share Posted November 26, 2012 its came out of the maxi fuse yes Link to comment Share on other sites More sharing options...
opelmantagsi Posted November 27, 2012 Author Share Posted November 27, 2012 might be getting closer Link to comment Share on other sites More sharing options...
mantasrme Posted November 27, 2012 Share Posted November 27, 2012 Have a look at http://www.vehicle-wiring-products.eu/VWP-onlinestore/terminalsnonins/mouldingterms.php and also http://www.polevolt.co.uk/acatalog/Terminals_for_Fuse_Boxes.html http://www.polevolt.co.uk/acatalog/Terminals_for_Special_Applications.html not sure if they have exactly what your looking for but they do look close Link to comment Share on other sites More sharing options...
opelmantagsi Posted November 27, 2012 Author Share Posted November 27, 2012 ^^ that first link is helpful. Polevolt could not help and would not post outside the UK ! - bizarre. most helpful so far have been www.jcrsupplies.co.uk Link to comment Share on other sites More sharing options...
opelmantagsi Posted November 27, 2012 Author Share Posted November 27, 2012 made a booboo here going with the Mondeo fuce relay box, should have done my home work first! (and known better that to think of using Ford stuff in my Manta) as I cant find the Ford Mondeo terminals I will need to change plans and go with the GM fuse / relay box so finally tracked down what I think the correct terminals are for the GM wiring Link to comment Share on other sites More sharing options...
opelmantagsi Posted December 3, 2012 Author Share Posted December 3, 2012 tracked down the GM wiring terminals from Mouser, these were shipped from Hong Kong (fast too) Link to comment Share on other sites More sharing options...
