20Let & Omega Box
Jason_d
you need a clutch release spacer too, omega box normally goes with dual mass flywheel, you'll be using either flat type or pot type xe flywheel, both of which are shallower, so clutch release needs spacing, or the cylinder will pop out of its bore when you press the pedal. I think we have some spacer kits left in stock
Right, I have one clutch spacer in stock, but another batch is being started tomorrow so they should be back in stock by monday next week.
The kit which is spacer plus the bolts to fix it to the release bearing backplate plus the bolts to fix the backplate to the gearbox, is £40 posted if bought away from ebay (will be £45 when listed on ebay)
will pm details to you Jason, and Gary, will be in touch next week when the new batch is ready to go
sorry for the delay.
