Retro Power Posted December 9, 2012 Share Posted December 9, 2012 We have Omega R25-R28-R30 gearbox clutch spacer kits available from stock again now, if you are fitting an omega gearbox to an xe, ecotec 4cyl engine or v6 ecotec with single mass flywheel then you'll need to space the hydraulic clutch release forwards to enable it to operate the clutch. this kit comprises a billet machined alloy spacer which fits between the release cylinder and its backplate, using the bolts supplied, to space it correctly. it also includes new bolts to secure the assembly to the gearbox. price is £45 delivered in the UK Quote Link to comment Share on other sites More sharing options...
